Old 09-28-2012, 12:32 AM   #1
Refrigerator make knocking
I have an True Refrigerator makes knocking noise while it is running..could someone help me .or lead me in the right directions.
Texasbill is offline   Reply With Quote
Old 09-28-2012, 06:19 AM   #2
An old Tradesmen
Let the person out of the frig, and he'll stop knocking in it.
Without more info, we can't help you much. Info like is it coming from the top or bottom of the frig. model number of the frig also helps.
Old 09-28-2012, 10:35 AM   #3
Move fridge out from wall..UNPLUG IT...check and clean any exposed coils and around compressor under bottom/back of fridge. Check compressor to see if mounting brackets/springs all firmly in place. Plug fridge back in and observe operation. If still knocking..likely that the compressor is going bad due to worn crank shaft/pistons. Likely time to replace.
OR could be just some toy stuck under compressor?
techpappy is offline   Reply With Quote
2007 Expedition A/C knocking Justins1171 Automotive Repairs 1 08-13-2012 07:34 AM
Burnham furnace knocking eam16 HVAC 2 01-16-2012 12:04 PM
Knocking pipes at end of pumping cycle PLO Plumbing 3 08-11-2010 10:58 PM
Knocking Copper Hot Water Pipes in Winter desron1964 Plumbing 5 11-19-2009 11:24 AM
Knocking sound when people walk by my bedroom dtran Flooring 1 01-16-2009 03:27 PM
