Refrigerant Type For Home System - HVAC - DIY Chatroom Home Improvement Forum
Old 07-05-2012, 09:49 PM   #1
Exclamation
refrigerant type for home system
ok, i need to know what kind of refrigerant my parents house uses. they went away on a cruise and i tried to use my dads gauges to fix the ac while they were gone. in the process all of the freon sprayed out of the blower thing outside and now the unit wont even turn back on. since my dad has alot of different colored bottles in his truck, which kind do i need and how much do i put in, and yes, i know how to read a pressures on the gauges cause i worked for my dad this spring.
austinrox is offline   Reply With Quote
Old 07-05-2012, 10:00 PM   #2
biggles's Avatar
how old is the system...most likely R-22 GREEN cylinder condenser outside info tag should be stamped for it but not the total charge.take the days temp around the running condenser add 30F then on the RED HI sie guage read the inside temp ring for R-22 and continue charging GAS ONLY into the suction insulated line...PURGE YOR HOSES before opening into the system.once you get near that ring temp gab the suction and it shoul go ice cold then stop charging....let it ettle out.check the condenser for a 10F rise on inlet air and air into your face and then down on the air hander 18F right at the furnace return vs supply....
Old 07-05-2012, 10:12 PM   #3
ok, the blower outside does say r-22, i didnt find a green bottle in the van but i did find a gray bottle with a yellow ring that has 22 written on it in marker. the same tag on he blower says factory charge 4.25 so im assuming i open the gauges for just over 4 seconds until the pressure reads what...? where do i get these temps you are talking about? he has a laser temp reader in his tool bag.
Old 07-05-2012, 10:37 PM   #4
JJboy's Avatar
Ask your dad....he's the best source to properly charge the system.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-05-2012, 10:41 PM   #5
bad idea, he is not going to be happy when he gets home. im just gonna put in about 4 seconds or so until the blower turns on again, then add a little at a time until it gets cold.
Old 07-05-2012, 11:22 PM   #6
I don't think you can do this right. It is not that easy. You better call a tech to help.
clocert is offline   Reply With Quote
Old 07-05-2012, 11:45 PM   #7
no i got this. i put in about 5 seconds or so of the 22 bottle. now the blower sounds like its gargling. do i need more, let some out, or just let it run for a while?
Old 07-06-2012, 12:02 AM   #8
ok, i got some help from another site. i let it all out and am going to start over. thanks for the help, ill post an update on the progress. feel free to chime in for advice in the process.
Old 07-06-2012, 12:57 AM   #9
oh well, the outside unit started gargling after i released the gas so i added more before i blew. now i need to hide the 5 empty bottles behind the shed or my dad will lose it. thanks for all of the advice.
Old 07-06-2012, 09:33 AM   #10
biggles's Avatar
did you purge the middle hose before connecting it to the cylinder.and when you connected to the system both red and blue guage...did you purge the suction blue hose/guage...if you didn't air is in the system along with the freon.you don't need to open the guages to read the pressures just onto the shradders fittings and it reads.the inside ring is temp for charging in relation to what freon your using.all freons stand at different pressure either in a system or in a cylinder..so did you PURGE
Old 07-06-2012, 10:03 AM   #11
Rewards Points: 292
Originally Posted by austinrox View Post
ok, i got some help from another site. I LET IT ALL OUT and am going to start over. thanks for the help, ill post an update on the progress. feel free to chime in for advice in the process.
You are under arrest. You have the right to remain silent..........
veesubotee is offline   Reply With Quote
The Following 2 Users Say Thank You to veesubotee For This Useful Post:
ben's plumbing (07-06-2012), hvactech126 (07-07-2012)
Old 07-06-2012, 12:51 PM   #12
I really want to see what kind of mess he will end up with. But I have to agree that he is a courageous young man ..
Old 07-06-2012, 01:59 PM   #13
An old Tradesmen
Rewards Points: 6,088
Yes, posting info that could get both him and his dad fines exceeding 30 thousand each is. Well, I won't call it courageous.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
Old 07-06-2012, 06:00 PM   #14
Got to be a joker from another site playing around. At least I hope so or dad's not going to be happy having to sell another 34,000 in product/service to break even on 5 missing jugs,assuming a 5% profit margin.
Old 07-06-2012, 07:45 PM   #15
Rewards Points: 582
iam with you marty seem to be a joke....not even someone stupid would post that
EVAP system fjacky Automotive Repairs 18 03-22-2011 04:51 PM
new construction- what type of system ugabulldog HVAC 2 03-06-2010 02:32 PM
Installing a New Central Air System vdu HVAC 7 09-01-2009 04:45 PM
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 08:31 AM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
