Refrigerant Problem - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 05-02-2012, 05:29 PM   #31
An old Tradesmen
Rewards Points: 6,068
Originally Posted by Doc Holliday View Post
If that happens, how to correct?
You would either replace the distributor lines themselves. or the whole coil and the TXV.
Maybe he'll call back and ask you to come back out anyway.
beenthere is online now
Old 05-02-2012, 05:33 PM   #32
I'm Your Huckleberry
Rewards Points: 2,270
He can call all he wants, I won't answer. He's tried twice already.
Thanks.
Doc Holliday is offline
Old 05-02-2012, 05:38 PM   #33
An old Tradesmen
You should answer his call, and be polite. Listen to him. If he is calling to ream you out because it was something simple, you learn something. If he is calling to ask you to come out cause the other company has no idea. Then you might want to consider telling him sure. You can work him in on the 10th, but no way before now as you just have so much work booked. And that your sorry that he didn't leave you come out and finish it today. He'll be kicking himself in the butt for the entire time he's waiting.
Old 05-02-2012, 05:48 PM   #34
Not happening. I went to his house at 9 at night after installing a complete system
and then a condenser
the first night. I had to drive an hour south the next day, yesterday, to install a new stat
and then drive two hours north to his place up in north Houston and spent a few hours diagnosing, included a nitrogen cleaning and a one hour long vacuum. Told him I'd be able to get the part today, he calls me this morning, I call lennox and get the price, call him back and then he says he's go someone else..?? No way, I know right away when to cut a relationship like that off.
If anything I should charge him for the time I spent on it. He's lucky I don't, just don't want to deal with him any more than I once had to.
Thanks.
Old 05-02-2012, 05:51 PM   #35
Wouldn't you know it, he's calling right this second!! Sucker!!
I kid you not, he just now called, again. Ha!!
Thanks.
Old 05-02-2012, 06:19 PM   #36
Rewards Points: 1,214
Tell him your booked for the next couple weeks and send him a bill.
He won't pay you but it will grind him up when he sees it.
COLDIRON is offline
Old 05-02-2012, 06:47 PM   #37
newtech's Avatar
Rewards Points: 164
Who installed these???
newtech is offline
Old 05-03-2012, 05:22 AM   #38
An old Tradesmen
Time to put this thread to bed.
Closed Thread
King valve as expansion valve... Danman5000 HVAC 14 09-18-2011 12:18 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
