Refrigerant Oil - HVAC - DIY Chatroom Home Improvement Forum
Old 04-14-2009, 08:43 PM   #1
refrigerant oil
Where can I purchase NEO 22 refrigerant oil or oil that is compatiable with the new R410A refrigerant use in ductless airconditioning?
joe 49 is offline   Reply With Quote
Old 04-14-2009, 08:44 PM   #2
An old Tradesmen
Rewards Points: 7,318
HVAC supply house.
How do you know how much oil to add?
Old 04-14-2009, 08:54 PM   #3
rerigerant oil
I am not adding it. I want it to put on yellow jacket flaring tool, to flare line sets for ductless air. I tried HVAC supply houses, none have it.
Old 04-14-2009, 09:06 PM   #4
An old Tradesmen
Just ask them for POE oil.
They may not carry that specific brand/viscosity.
You can always go to a refrigeration supply house.
Refrigeration has been using POE oil longer then A/C units.
Old 04-15-2009, 06:45 AM   #5
biggles's Avatar
you don't need oil on a flaring tool tip if it is soft copper after the cut justreem the inside out to clear the burrs out so you get a good flare.drop of 3 in 1 oil on your finger and run it around the point of the flare cone will help and not contaminate the system.
Old 04-15-2009, 12:50 PM   #6
Thanks for your help. I got the POE oil.
Old 04-15-2009, 02:28 PM   #7
An old Tradesmen
Your welcome.
central air unit removel big mikec HVAC 15 02-26-2009 03:39 PM
Buying HVAC Equipment EarthCreepin HVAC 3 08-01-2008 09:00 PM
Sealing the roof jack holding refrigerant lines. pines HVAC 1 08-16-2007 05:58 PM
A lightning Strike? DCK HVAC 13 07-27-2007 01:43 AM
Underground refrigerant line - bad idea?? hennyh HVAC 1 11-30-2006 01:14 PM
