-   -   refrigerant oil (http://www.diychatroom.com/f17/refrigerant-oil-42463/)
joe 49 04-14-2009 08:43 PM
refrigerant oil
Where can I purchase NEO 22 refrigerant oil or oil that is compatiable with the new R410A refrigerant use in ductless airconditioning?
beenthere 04-14-2009 08:44 PM
HVAC supply house.
How do you know how much oil to add?
joe 49 04-14-2009 08:54 PM
rerigerant oil
I am not adding it. I want it to put on yellow jacket flaring tool, to flare line sets for ductless air. I tried HVAC supply houses, none have it.
beenthere 04-14-2009 09:06 PM
Just ask them for POE oil.
They may not carry that specific brand/viscosity.
You can always go to a refrigeration supply house.
Refrigeration has been using POE oil longer then A/C units.
biggles 04-15-2009 06:45 AM
you don't need oil on a flaring tool tip if it is soft copper after the cut justreem the inside out to clear the burrs out so you get a good flare.drop of 3 in 1 oil on your finger and run it around the point of the flare cone will help and not contaminate the system.
joe 49 04-15-2009 12:50 PM
Thanks for your help. I got the POE oil.
beenthere 04-15-2009 02:28 PM
Your welcome.
