Old 06-30-2009, 09:38 PM   #1
zpm
yeah, right
Default Refrigerant Level
I've got an early 90's rooftop unit that takes 7 pounds of R-22. The system hasn't been working very well so I called out a recomended company. The tech hooks up his gauges and tells me I have less than a pound left. I'm getting 10 degrees of delta-T across the evap coil.
Q1 - Can you make a reasonable estimate of how much refrigerant is in the system based on the pressure gauges?
Q2 - If the system were really that low on refrigerant, would it still be cooling 10 degrees?
Honey, does this tool belt make me look FAT?
zpm is online now   Reply With Quote
Old 06-30-2009, 09:50 PM   #2
biggles's Avatar
weighing freon in or taking it out is the only way to find out whats left in a system.if you only had that ONE pound left the machine would of been off on low pressure safty....the compressor would have almost nothing to compress to start the cycle.unless the liquid line is filled it can't make a temperature drop on the evaporator coil when it hits the metering device.you need a good nitro pressure test to 400psi and the leak will find the tech if it is bad.then a solid vacuum and pulling 500/250 microns will back up a tight system to take the new charge.
Old 06-30-2009, 10:36 PM   #3
An old Tradesmen
If youo had less then a pound left, you wouldn't have a 10° temp drop,
He made a guess.
Old 06-30-2009, 11:12 PM   #4
zpm
yeah, right
Originally Posted by beenthere View Post
He made a guess.
And then he tried to sell me a new system. I've got no problem getting a new system if I need one, and I may, but giving me obviously bad info seems like a setup.
Should I tell them to come back and charge the system?
How would I know if they actually do it right?
Old 06-30-2009, 11:37 PM   #5
Master Plumber/Mechanical
Almost all techs carry a portable scale.
Have the tech weight the jug of freon in front of you before going on the roof and after he come down from charging it. This will tell you how much freon he put in.
This will keep him honest
Plumber101 is online now   Reply With Quote
Old 06-30-2009, 11:56 PM   #6
An old Tradesmen
Not really.
If he has to go on teh roof to charge it.
He could simply blow off a couple pounds from the cylinder, until it says 7 pounds.
I'd simply call another company.
Old 07-01-2009, 12:03 AM   #7
That's true Been
If it were me I'd shimmy up the ol roof with the guy and then ask where the scales are.
Just to prove a point
Old 07-01-2009, 01:27 AM   #8
zpm
yeah, right
I don't think this company is that dishonest. Maybe the Jr. Tech gets a little something for every sale he makes so he stretches the truth, not realizing it might snap back in his face.
I'm more concerned with being able to verify that they put the correct amount of R-22 into the system, whether it be 1 or 5 pounds. Just because a guy has the right tools doesn't mean he knows what he's doing.
I took a look at my actual temp data from last summer from comparable days.
7/23/2008, 16:00
outside 100.82
return 78.01
evap 63.81
delta-t 14.2
6/30/2009, 16:00
outside 101.82
return main 83.30
evap 71.85
delta-t 11.45
I've lost almost 3 degrees of cooling. There's probably a tiny leak, but at this point I'm thinking to tell them just charge it up and screw any leak tests and fixes. This system isn't worth pumping a lot of money into. If/when it bleeds out again I'll look at a new system. Any problems with that plan?
Old 07-01-2009, 06:48 AM   #9
An old Tradesmen
No. They can do a gas n go.
Old 07-02-2009, 08:32 PM   #10
zpm
yeah, right
Resolution:
Talked with the service manager and explained the bad vibes I got from the tech. They sent out another tech this morning to fill er up. Took 2 pounds.
7/2/2009, 4:13 pm
outside 102.09
return 78.01
evap 59.11
delta-t 18.9
Its comfy in the house and the A/C is keeping up and actually cycling.
Interesting how just a few degrees makes such a huge difference.
Old 07-02-2009, 09:36 PM   #11
An old Tradesmen
Amazing what 2 pounds of refrigerant can do.
More On This Topic
Part 2 - Learn how to string a fender stratocaster electric guitar in this diy guitar setup video. Read More »
Learn how to tune a fender stratocaster electric guitar in this diy guitar setup video. Read More »
Learn how to clean a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Part 1 - Learn how to string a fender stratocaster electric guitar in this diy guitar setup video. Read More »
One of my favorite John Hurt songs is one called "Sliding Delta." And, it's because it has some interesting note additions but, it kind of has this really interesting kind of rhythmic turnaround that kind of makes it sort of skip a beat. So, "Sliding... Read More »
Leveling Kitchen Cabinets for Granite - how level?? vsheetz Kitchen & Bath Remodeling 11 10-21-2009 07:15 PM
How do I get my ceiling level? Leah Frances Building & Construction 4 01-10-2009 03:12 PM
Is it bad to use mortar to level a floor? CB2007 Flooring 4 10-01-2008 10:38 AM
How to level small patch of cured concrete? RDS General Discussion 11 06-05-2008 02:41 PM
How level does a footing need to be? tripower Building & Construction 1 05-03-2007 10:59 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
