Refrigerant Hose Ruptured! - HVAC - DIY Chatroom Home Improvement Forum
Old 07-05-2013, 03:59 PM   #1
Refrigerant hose ruptured!
Hi all
After buying a second hand portable split to replace my broken old one, when moving it onto position I heard a crack and all the refrigerant leaked out.
It turns out that the high pressure copper line had a tight king in it and just snapped, and leaked all the refrigerant out. This happened underneath the plastic cord.
The line has snapped right at the union:
http://imgur.com/auQit7d
http://imgur.com/2AtMcdl
2 questions, Can I braze it back, and how do I go about recharging a portable AC unit? It uses R407C.
Thanks in advance!
alexanderfitu is offline   Reply With Quote
Old 07-05-2013, 04:30 PM   #2
An old Tradesmen
Rewards Points: 8,168
Probably can be brazed back together. Would need to see the part that is still in the black cover.
Need a vacuum machine to vacuum the system after fixing the line. And then a set of manifolds, and of course, a tank of R407C. Then an accurate scale to weigh it in.
Old 07-05-2013, 04:32 PM   #3
The part thats in the black cover is just the quick connect valve and a conical piece of copper that goes from the large valve down to the small pipe.
Im pretty sure there are no recharge ports for this AC, can the recharge be done via the quick connect ports?
Is this something a mobile AC tech will likely do?
Old 07-05-2013, 04:35 PM   #4
An old Tradesmen
Will need schrader fittings.
Doubt a mobile(609) tech will do it. But could be wrong.
Old 07-05-2013, 04:42 PM   #5
Many thanks.
I will have to call around. It would be a shame to have to throw away a perfectly good unit just because of a leak!
Repairing Garden Hose Connection cl6120 Plumbing 9 09-12-2012 09:20 AM
King valve as expansion valve... Danman5000 HVAC 14 09-18-2011 11:18 AM
Sprayer hose removal zubby01 Plumbing 0 07-29-2011 12:51 PM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 12:52 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
