Which Refridgerant Lines Are Operational On Ac - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 05:28 AM   #16
An old Tradesmen
Rewards Points: 6,116
Originally Posted by plummen View Post
ive only actually seen it once ,thats why i wanted to make sure!
although ive never seen a lineset run under a concrete slab before
Line set under slab is common in some areas, Florida for one.
Old 12-20-2011, 10:59 AM   #17
noshoff
two linesets(4 lines)
Originally Posted by Doc Holliday View Post
someone kill me now.
doOd, that is not two sets, that's the ONLY set.
I pulled one lineset out of the stemwall of the foundation. It obviously was the non operational lineset. The lineset up in the ceiling therfore is the lineset causing cool air to blow into the room. ..........two sets!
shadowbuilder is offline   Reply With Quote
The Following User Says Thank You to shadowbuilder For This Useful Post:
Doc Holliday (12-20-2011)
Old 12-20-2011, 06:35 PM   #18
I'm Your Huckleberry
Rewards Points: 2,270
That's not what it sounded like in the post where you described two lines going to the evap and two lines going to the condenser whcih would make that particular lineset one set but gOod, you got it at least.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-20-2011, 06:40 PM   #19
HVAC Tech/ Browns Fan
Lot of them here in Dayton.We do the Wright Patterson Air Force base and nothing but line sets in concrete slab. That the housing part
Tator1076 is offline   Reply With Quote
Connect Air Cond Drain to House Waste lines AdamOJ Plumbing 19 11-23-2011 07:47 AM
Low point in water supply lines dave11 Plumbing 3 02-01-2011 08:13 PM
slow hot water lines sobro Plumbing 3 11-05-2010 11:44 AM
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 06:02 AM
water lines on slab toolbelt Tina Plumbing 6 05-21-2009 08:05 PM
