Refer. Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 06:07 PM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 382
Does it have the ounces of refrigerant listed on the rating plate? Heck of a lot easier to weigh it in. We used to have those liquid charging measuring clear cylinders in school. Now that was cool to watch and use.
http://cgi.ebay.ca/Robinair-43678B-D...item4cf07d4a2b
Old 07-22-2010, 06:18 PM   #17
An old Tradesmen
Rewards Points: 8,162
I use to carry a 5, and a 10 pound one.
Old 07-22-2010, 06:46 PM   #18
Rewards Points: 85
Ita a beverage air
I just called them to see how many oz. it takes, but all I got was an answering service.
I can't find a tag or a model number.
I use to have a dial a charge now I use a dig. scale.
mikethe ductman is offline   Reply With Quote
Old 07-22-2010, 06:47 PM   #19
Rewards Points: 85
I bumped it to the max and it was right at 40 degrees.
Old 07-22-2010, 11:18 PM   #20
An old Tradesmen
And the frost at the compressor got heavier.
Old 07-23-2010, 03:37 AM   #21
Rewards Points: 85
Yes, I removed some freon and most of the frost went away.
The pressure started out at 26 and ended up at 18, box temp. was 38.
Old 07-23-2010, 06:08 AM   #22
An old Tradesmen
See how it work after a couple days.
Old 07-23-2010, 07:11 PM   #23
Rewards Points: 85
Called Beverage Air this morning.
They said the unit holds 11.5 oz.
Oops!
Looks to be a little over charged.
Old 07-23-2010, 07:42 PM   #24
Hvac Pro
yuri's Avatar
Rewards Points: 382
Thats what I waz thinkin. 8 oz is what a small house fridge uses. A couple oz is a big deal with a cap tube system.
Old 07-23-2010, 08:14 PM   #25
An old Tradesmen
I think I said its overcharged once or twice. LOL
Old 07-23-2010, 08:25 PM   #26
Hvac Pro
yuri's Avatar
Rewards Points: 382
I must have an honest face.
Old 07-23-2010, 08:40 PM   #27
An old Tradesmen
I think its that Canadian accent.
Old 07-26-2010, 07:10 AM   #28
Rewards Points: 85
Been busy the past couple days.
I put some water in it 24 hours ago.
At 9 the highest setting the water was at 37 degrees, the low side at the end of the cycle was around 15-16 and I saw no frost on the line.
http://www.acitydiscount.com/Used-Be...110573.1.1.htm
Now if I can just figure out how to mount the start cap onto the compressor cover or maybe zip tie it to the cross member.
Old 07-26-2010, 07:14 AM   #29
An old Tradesmen
Those little compressors usually come withe the start cap already mounted on the compressor.
Old 07-26-2010, 07:28 AM   #30
Rewards Points: 85
When I got the cooler there was no cover for the compressor terminals"the cut off switch is exter. and mounts in the cover" and the relay for the start cap. was missing.
The new compressor came with all that and a good wireing diagram.
The only thing it lacked was a good picture on how to mount the start cap.
But nothing zip ties, duct tape or rubber bands can't fix.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
