Reduce Gas Input To Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2008, 03:14 PM   #1
Reduce gas input to Furnace
The furnace is Carrier 58CVX070-12 in downlow mode. With a 1300 sq ft house in Northern Calif. the furnace runs very short intervals. So the house has wide temperature swings with long off times.
Yet I think the unit is not really that much oversized, if at all. It's just that most of our weather is not very severe, but we need the availability to handle colder weather.
I'd like to be able to reduce the gas input simply by adjusting the manual input gas valve. I was able to do it in another house and furnace, it worked fine. If it's ok with this unit I would just close the valve maybe 30-45 degrees.
I would think if I go too far the system would shut down or run too long. Will appreciate comments.
Bob
bobn3faw is offline   Reply With Quote
Old 11-05-2008, 04:25 PM   #2
Big no no.
Starving it for gas will decrease the efficiency and could damage the system.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-05-2008, 06:53 PM   #3
An old Tradesmen
Rewards Points: 6,544
Also tends to cause condensation in the heat exchange, and rot it out.
That not covered by warranty.
Did your installer only set it up to run in second stage.
If its not oversized, then in first stage, it shouldn't over shoot temp setting.
Did you have them install the Infinity controller also?
Old 11-05-2008, 10:50 PM   #4
Yep. They can even soot up too,
hvaclover is offline   Reply With Quote
Old 11-06-2008, 12:15 AM   #5
OK guys thank you. I think it operate in 2 stages, but I should verify it again.
Bob
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
Add-on Wood furnace billmac HVAC 3 06-18-2008 10:17 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
