Recovery Machines. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-21-2013, 12:09 AM   #16
Experienced HVAC Tech
HVAC1000's Avatar
Originally Posted by Doc Holliday
not if there's not any refrigerant in the system which defeats the need of a pump down in the first place so yes, you do, otherwise the refrigerant in the line set outside of the condenser service valves (if closed) will escape to atmosphere.
am I missing something?
Yes you are, now just go to any supply house, have you really never seen these basic tools. Every other tech has at least one core removing tool to change out cores without loosing system charge. I have two so I can pull from both sides at once with less restrictions. I didn't think they were that new of a tool
HVAC1000 is offline   Reply With Quote
Old 06-21-2013, 12:11 AM   #17
I'm Your Huckleberry
Rewards Points: 2,270
as always it's my pleasure learning from you, Obe-one Kenobi, but let's hypothesize a different scenario. Can you pump down down a system, close the valves thus trapping the refrigerant in the compressor and recover through one side quicker, obviously after opening whichever side you chose to recover from, then from an open system? would there be any benefit to doing as such and mind you this si with the cores in place.
I'm assuming if I pumped down, removed the cores and then hooked up it'd be faster then how I went about it with the cores seeing as how there's more release room without the cores but would a pump down and pressurized release be better?
I confused myself. Of course a pump down and then no cores recover would be quickest, right?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 06-21-2013, 12:13 AM   #18
HVAC1000's Avatar
Just recover without the cores using the core removing tool
Old 06-21-2013, 12:16 AM   #19
in 12+years I've never had one. heard of them but never paid attention to their focus. I guess it's main adjacent function is for recovery, right, as in when a compressor is locked or burned out?
Thanks.
Old 06-21-2013, 12:18 AM   #20
An old Tradesmen
Rewards Points: 6,464
No, that would take longer.
CRTs are for replacing cores that leak with out having to recover, and to remove the cores for quicker recovering, and for quicker vacuuming.
Old 06-21-2013, 12:19 AM   #21
HVAC1000's Avatar
That and if you just want to replace cores without pumping down also let's you pull a vacuum a lot faster.
Old 06-21-2013, 12:25 AM   #22
strange how I've never really recovered a system in all my time in this trade. no, I'm not bragging about it, I actually feel kinda like a hack, but it is what it is and I thank you guys for the help.
Thanks.
Old 06-21-2013, 12:29 AM   #23
my usual is pump down, remove cores, braze what needs brazing, nitrogen pressure test without cores, remove gauges from service ports without cores to allow any trash to escape, install cores and then vacuum.
now if it's a compressor change out then the same but with the valves open. I pressure test without the cores and dump the junk, then install the cores and vacuum. but I'm guessing this tool makes a substantial difference if for nothing else in saving time...????
Thanks.
Old 06-21-2013, 12:36 AM   #24
HVAC1000's Avatar
For sure. I used to do it with cores in. Then tried with the tool and it was so much faster. The first few times I charged a system after removing cores I kept over charging them because it was so quick. Then I learned I might want to do that part with cores in to get better accuracy
The Following User Says Thank You to HVAC1000 For This Useful Post:
Doc Holliday (06-21-2013)
Old 06-21-2013, 06:02 AM   #25
biggles's Avatar
hot recovery tank killed you on time right off,what ever happened to 15lb tanks with a vacuum on them go right for the LL without the machine and 2 hoses are a must.
Old 06-21-2013, 04:33 PM   #26
Rewards Points: 154
and get the valve core tool with the ball valve. Its a lot better than the one with the screw type cut-off.
Patrick Eubanks is offline   Reply With Quote
The Following User Says Thank You to Patrick Eubanks For This Useful Post:
HVAC1000 (06-21-2013)
Old 06-21-2013, 05:30 PM   #27
plus I had a restricted filter internal to the condenser, before the service ports. the one line was pulling overtime!
I have extra hoses, they're just on my personal truck...
Thanks.
Old 06-21-2013, 05:47 PM   #28
An old Tradesmen
You need one or two of thee then.
http://www.bing.com/images/search/?q...50cdeb1&rxc=12
heat recovery ventilator retrofit? longshanks HVAC 6 02-22-2013 04:00 PM
Windows XP recovery console lifestooshort81 PC Repairs & Upgrades 18 01-16-2013 01:12 PM
How to remove compressor from cooler? nicksab HVAC 33 08-23-2011 06:52 AM
Geothermal recovery against house foundation dirtman HVAC 0 01-05-2011 02:54 PM
purchase new recovery unit wetbar HVAC 1 06-07-2009 08:11 PM
