Reconnect HVAC To Cooktop - HVAC - DIY Chatroom Home Improvement Forum
Old 03-28-2015, 08:43 AM   #1
Rewards Points: 20
Reconnect HVAC to Cooktop
Due to new countertops being installed, I need to reconnect the HVAC pipes to the downdraft vent on the cooktop. What I noticed when I took it apart was that the duct was sealed to the bottom shelf of the base cabinet and not connected to the vent on the floor using the cavity under the cabinet as a chamber. Is that correct or should I connect directly to the flange on the subfloor? Also, there were a bunch of 90 degree elbows from the cooktop to the hole in the base cabinet that did not fit tightly. Can I use a flex pipe to connect or should I stay with the galvanized? (The second pic is rotate 90 counterclockwise for some reason)...
Reconnect HVAC to Cooktop-img_1793.jpg   Reconnect HVAC to Cooktop-img_1792.jpg
dnwong is offline   Reply With Quote
Old 03-28-2015, 08:48 AM   #2
Rewards Points: 20
How about these:
http://www.lowes.com/pd_127188-42471...r|1&facetInfo=
or this one?
http://www.lowes.com/pd_328921-131-L...r|1&facetInfo=
Old 03-28-2015, 10:41 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 116
Stay with galvanized. Grease will collect in the grooves of flex pipe and be a fire hazard. The grooves also slows down the airflow a lot.
Gas Cooktop - Install Pressure Regulator Help Smahoney6 Appliances 2 02-03-2015 11:19 AM
36" Gas Cooktop Quandry JulieMor Appliances 10 02-15-2013 06:39 AM
Cooktop cut-out accuracy... jdrunbike Appliances 5 04-13-2011 10:46 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 04:55 AM
Electric Cooktop too slow to heat coachgns Appliances 1 02-05-2011 03:45 PM
