Recommend Heat Only Programmable Thermostat? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2007, 09:19 AM   #1
recommend Heat only programmable thermostat?
Hi,
Can anyone recommend a good heat only programmable thermostat?
I need to replace my old mercury thermostats and not sure what I should look at. Thanks!
pesphoto is offline   Reply With Quote
Old 12-26-2007, 11:31 AM   #2
Union HVAC Tech.
Honeywell Pro 6000 is a good start, Visionpro 8000 is the Rolls Royce.
bigMikeB is offline   Reply With Quote
Old 12-26-2007, 11:34 AM   #3
Thank you! I'll check those out.
Old 12-26-2007, 11:37 AM   #4
Union HVAC Tech.
Anytime. I like the touch screen on the 8000, that's what I have in my own house.
Old 12-26-2007, 11:41 AM   #5
I currently have the old circular mercury ones, are these you showed me DIY installation? Doesnt look too difficult.
Old 12-26-2007, 11:46 AM   #6
Union HVAC Tech.
Yes they are. You use two wires, one on the R (Rh) terminal and the other on W. The new stats will have the same designations. The biggest thing is programming options, just read the menu in the install guide and go one step at a time. It is easier than it looks, just read the booklet.
Old 12-26-2007, 11:56 AM   #7
Great, thanks again. Heading out to see what the stores have in stock
Old 12-26-2007, 01:30 PM   #8
Rewards Points: 150
They might be not 'heat only' thermostats, in that they have logic to activate cooling, but if you don't connect the cooling terminal, the 'stat will essentially be heat-only. And so, about any modern programmable unit will do.
scorrpio is offline   Reply With Quote
Old 12-26-2007, 01:42 PM   #9
Thanks Scorpio,
are there specfically "heat only" thermostats?
Old 12-26-2007, 02:57 PM   #10
Union HVAC Tech.
The programming in the tstat will make it "heat" only. If you aren't familiar with the item, why comment? Check out the thermostats at http://www.hotfreshcool.com/index.html The focus pro is a good choice.
Old 12-26-2007, 06:11 PM   #11
Thanks for the link bigMike. I like the looks of it.
Old 12-26-2007, 06:26 PM   #12
ok, just took the plunge and ordered 2 Honeywell Focus Pro 6000 models. Now I need to find where i can dispose of the old mercury ones when I take those out.
What do you keep your programmable thermostat set to J187 General DIY Discussions 2 12-08-2007 10:05 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 12:04 AM
