Old 05-31-2007, 01:27 PM   #1
recharging my goodman ac
I have the refrigererant and the gauges just wondering which port is the low pressure one. is it the one connected to the larger pipe or the smaller one on the condenser? it only leaks enough to need a recharge every two to three years.
pittsburghirish is offline   Reply With Quote
Old 05-31-2007, 03:18 PM   #2
Diesel Fitter
low is big hook up the gauges first get running pressure if you got it right than proceed. Just as a safety step. then you can hook up the can purge the yellow line and do what you gotta do.
mikemy6 is offline   Reply With Quote
Goodman GMP100-3 Forced air furnace sylvia HVAC 23 12-18-2011 10:49 AM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
Goodman furnace problems GMT045-3A wcoent HVAC 7 12-18-2006 11:30 PM
Goodman tempermental - cycles on / off typhoon55 HVAC 2 01-07-2006 12:32 PM
