Old 07-14-2010, 05:50 AM   #1
recharging heat pump compressor
i installed a new compressor on a heat pump package unit, and would like to know the correct way to charge it apon start up ?
smfixit is offline   Reply With Quote
Old 07-14-2010, 07:12 AM   #2
After a leak check and vacuum pump to 500 microns weigh in the charge. Hopefully you replaced the biflow drier when the system was open.
Old 07-14-2010, 07:18 AM   #3
An old Tradesmen
By weight. The data lavel of the package unit, should have its operating charge on it.
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Heat Pump Control Wiring Questions IBuiltPools HVAC 3 01-14-2010 02:45 PM
heat pump compressor not running... hotnva HVAC 6 08-21-2009 11:08 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
