Recessed/Can Lighting Heat Loss? - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 09-23-2009, 08:50 PM   #46
Thank you.
hvaclover is offline   Reply With Quote
Old 09-23-2009, 09:09 PM   #47
Registered User
Termite's Avatar
Originally Posted by hvaclover View Post
Thank you.
Sent you a PM as well. (not as a moderator)
Old 09-24-2009, 04:01 AM   #48
newtech's Avatar
Rewards Points: 164
Originally Posted by newtech
I don't want to get into the middle of an argument here if it can be done to code or not..... If the op wants to add a computer fan .... He would need a 120ac to 12vdc transformer or power supply. Depending on which fans he decides and how many he might need a 450 power supply, then run all the wires to code. If a fan puke's how will he access it? Back up into the attic? Also the fans would need to be interlocked with the light switch so they would not run all the time. So you are wasting more ac to run the fans. I hope that Yoyizit can spit out some numbers as to what I am talking about. All I know is that it isn't cheap to run power supply's.
You do know we are talking residential?
I meant 450w power supply. 120vac/12vdc
newtech is offline   Reply With Quote
Old 09-24-2009, 05:10 AM   #49
An old Tradesmen
Rewards Points: 6,860
Originally Posted by thekctermite View Post
and it sets a bad example
No soup for you.
Old 09-24-2009, 08:01 AM   #50
Originally Posted by beenthere View Post
No soup for you.
That's Swampy's line, Been as he boots people out...LOL
Just happy we are back to status quo
Old 09-24-2009, 05:13 PM   #51
newtech's Avatar
Rewards Points: 164
Oh joy... The fun will continue
Old 09-24-2009, 05:31 PM   #52
An old Tradesmen
Yea I know.
Old 09-24-2009, 05:53 PM   #53
Yes it will.
That's why we all come here.
Old 09-24-2009, 06:18 PM   #54
Registered User
Termite's Avatar
Absolutely.
Old 10-03-2009, 08:32 PM   #55
pot lights
How about using the vapour boots and installing the IC rated lights in them. Does that make them better? Thanks.
beech is offline   Reply With Quote
Old 11-14-2009, 08:23 PM   #56
potlights in insulated ceiling
If you use the IC rated can do you still need to install those blue vapor boots? Thanks
Reducing Skylight Heat Loss? longshanks Roofing/Siding 26 12-04-2009 12:37 PM
duct heat loss drewhart HVAC 2 02-05-2009 03:18 PM
HUGE Icicle problem & Heat Loss zaibas Roofing/Siding 5 02-01-2009 03:33 PM
heat loss (sensible and latent) drewhart HVAC 6 01-29-2009 05:42 PM
