Recessed/Can Lighting Heat Loss? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-09-2009, 01:01 AM   #1
I'm remodeling and I'd like to add maybe 5-6 recessed lights in the kitchen of my 1-story house. I actually wouldn't mind a few more (along with some in-ceiling speakers) in the living room, but the kitchen is my first priority. This being a single story, the space above these rooms is unconditioned attic.
20 minutes of Googling later, I'm left wondering if the heat loss (even from sealed can fixtures) would make this a pretty bad idea. I'm in the Twin Cities (MN) and whatever I can do (within reason) to increase thermal efficiency has seemed to be worth it.
Of course, you can build boxes of drywall various other materials to further seal/insulate the penetration/mini chimney you've added to your ceiling. Cooler CFL lighting helps reduce the stack effect, but the bulbs aren't terribly dimmable. My thinking is, wouldn't you be better off not doing this to begin with? Or will the mitigation measures offset the problems? Seems like for the cost and hassle of doing recessed lighting the right way, I could buy some pretty nice flush mount and pendant fixtures.
TomServo is offline   Reply With Quote
Old 09-09-2009, 04:31 AM   #2
sweaty
Rewards Points: 276
Personally, I would forgo the recessed lights and keep your house intact, especially in such a cold area as yours. You can find really elegant light fixtures that don't hang down far from the ceiling. After you put those up, you should still seal around the electrical boxes in the attic and then pile on the insulation.
sweaty is offline   Reply With Quote
Old 09-09-2009, 09:16 AM   #3
I put recessed lights in with CFL - IC cans = in contact with insulation
I did not have any snow melt over the cans - cathedral ceiling
I did make sure I insulated over the cans
With an attic above you have enough room to insulate/build a box
If you think that's too much trouble then go another route
I'll have 7 recessed cans in my kitchen when I am done
But there is a walk-in closet over the kitchen
Old 09-09-2009, 12:35 PM   #4
Recessed lighting can cause a chimney effect that can pull the air from the space they serve.
There was a 100 post thread about the hows and whys they do this at hvac-talk. On the surface it seems to be a simple solution. It ain't .
I would wait for Beenthere to show. He's our resident building envelope specialist.
hvaclover is offline   Reply With Quote
Old 09-09-2009, 12:49 PM   #5
Newbie Bill
Rewards Points: 520
OK, now you have my attention too.
We just had 9 cans installed in our kitchen so am very interested to hear what other's thoughts are.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 09-09-2009, 12:53 PM   #6
Trust me you are in for an education when Beenthere shows.
Old 09-09-2009, 04:29 PM   #7
WaldenL's Avatar
Rewards Points: 268
I would imagine that there's no way a recessed can can be better than no hole in the drywall, but they do make closed cans. That is a can that doesn't allow air to pass through it. For example: http://www.lowes.com/lowes/lkn?actio...00I&lpage=none
WaldenL is offline   Reply With Quote
Old 09-09-2009, 04:40 PM   #8
I look forward to it.
Old 09-14-2009, 05:47 PM   #9
I'm still interested in any thoughts on this. My electrician said not to worry, of course, but I'm sure he'd like to install some recessed lighting for me.
Old 09-14-2009, 08:06 PM   #10
Anyone have numbers on the heat loss for these lights? I know I saw a formula for stack effect in some HVAC or building handbook.
http://en.wikipedia.org/wiki/Stack_effect
"The glass bulb of a general service lamp can reach temperatures between 200 and 260 degrees Celsius (400 to 550 degrees Fahrenheit)"
Can you use a small fan to redirect the warm air from several fixtures back into the living space?
Old 09-19-2009, 01:21 AM   #11
I think the simpler solution would be to use a cooler bulb, specifically a CFL.
Of course, you'd lose dimming capabilities. Yes, there are dimmable CFLs, but AFAIK, they still don't work worth a .
Old 09-19-2009, 08:51 AM   #12
I have dimmable CFL bulbs in the dining room, they do work
I'm not sure on the Mfg
The only reason I bought them they were marked down to .49
I do know a lot of the CFL bulbs will not (would not ?) dim properly
Plus they are usually $7 +/- a bulb
Not sure if the Mfg's have fixed the problems
Old 09-19-2009, 12:26 PM   #13
An old Tradesmen
Rewards Points: 6,576
They do make air tight recessed lights.
Ask your electrician about them.
If he can't find out about, or get you any. You got the wrong electrician.
Old 09-19-2009, 01:28 PM   #14
Some people don't like the color temperature of CFLs, so even better would be LEDs whose color temp. is adjustable, but it'd be pretty sophisticated to be able to dim LEDs and maintain their color temp. Maybe some company does that.
http://www.google.com/search?client=...UTF-8&oe=UTF-8
But regular incands. also change color temp. with dimming.
Old 09-20-2009, 12:16 AM   #15
I already found the wrong electrician. He wanted to charge me $3800 to add a few outlets to existing circuits, add one new circuit, and do 5-6 recessed lights. Sure, without knowing all the details, you can't see how outlandish that is, but I don't have any doubt that I can do those same things for under $300 and a few hours of my time.
So, beenthere, I've heard tell that you're the resident building envelope guru, and you have no qualms with perforating my nice, solid, insulated ceiling with a handful of recessed lights? I certainly would use air tight/IC cans and insulate and seal them to the best of my ability.
Reducing Skylight Heat Loss? longshanks Roofing/Siding 26 12-04-2009 01:37 PM
duct heat loss drewhart HVAC 2 02-05-2009 04:18 PM
HUGE Icicle problem & Heat Loss zaibas Roofing/Siding 5 02-01-2009 04:33 PM
heat loss (sensible and latent) drewhart HVAC 6 01-29-2009 06:42 PM
