Recent Furnace Installed - Some Dumb Questions - HVAC - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 11:18 AM   #1
Probably some dumb questions but....
I recently had a 96% furnace installed (a Bryant) that has a variable speed blower. We kept the 8 to 10 year old central air.
Questions:
1. The new unit has a condensation pump that drains to our utility sink. Is there any maintenance that needs to be done on that pump? It's working fine, but I figure since it constantly has water flowing through it, perhaps I need to clean it once in a while or add some bleach or something?
2. Our prior furnace was a single-stage 80% York unit. As such, it was either fully on or fully off - no variable speed. We love the new variable speeds for heating and was wondering: does this also work with the air conditioner? I'm assuming it will, since my understanding is that the blower is the same for both heat and air?
I should have asked the installer this stuff but didn't think of it at the time.
mark2741 is offline   Reply With Quote
Old 03-03-2013, 12:03 PM   #2
For the condensate you shouldnt have to do anything, when we install a pump we generally tie it in directly to the a plumbing drain, a bit of bleach here and there wouldnt hurt.
With a two stage furnace its not the blower that adjusts, but the flame. At least is my understanding and from the bryants i've installed never had the actual blower speed change without adjusting the fan speed ports on the board
ahrens is offline   Reply With Quote
The Following User Says Thank You to ahrens For This Useful Post:
mark2741 (03-03-2013)
Old 03-03-2013, 12:06 PM   #3
Thanks.
I should have mentioned: this is the furnace I have -
http://www.catalog.bryant.com/wcs/pr..._SIT70,00.html
It is 2 stage burner, but variable speed blower.
Old 03-03-2013, 12:11 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
The variable speed blower will ramp up/down when the AC starts but unless you got a 2 stage AC it will settle on a high speed for the AC. You should however get the installer to check the blower speed for the AC and the freon level when warm enough. The newer furnaces have the AC speed set for maximum capacity and most of them need to be slowed down with the dip switches on the circuit board for better dehumidification etc. Depends on the AC size in tons. Get the AC model # and I/we can probably give you the tons and then we look up the tonnage capacity of your furnace fan to see if it matches. Also need the complete model # of the furnace.
Old 03-03-2013, 12:13 PM   #5
Originally Posted by mark2741 View Post
Thanks.
Aahhh i got ya now, we've only installed a few 925T's mostly around here people go with the lower end units
Old 03-03-2013, 02:32 PM   #6
Rewards Points: 196
Put 1/2 cup of bleach in a gallon of hot tap water, and pour it into the pump.The pump will cycle a couple times as you pour it in.Do it at the start of each season.
HVACTECH96 is offline   Reply With Quote
Old 03-03-2013, 02:46 PM   #7
An old Tradesmen
Rewards Points: 7,284
Even on a ECM or PSC blower it changes speed from first stage to second stage. or the temp rise would be either too much in second stage or not enough in first stage.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (03-03-2013)
Old 03-03-2013, 02:48 PM   #8
An old Tradesmen
Questions:
It can be set up to do a slow ramp up in cooling. And or with the right thermostat it can be wired and set up to run the blower slower to remove more humidity, if the humidity gets higher then the dehumidistat is set for.
Old 03-03-2013, 03:29 PM   #9
Roofmaster
Rewards Points: 2,210
There are no dumb questions.............................er, sorry, yeah there really are, but yours surely isn't one of them.
Old 03-03-2013, 05:26 PM   #10
Rewards Points: 12
The blower adjusts according to whether your in the high or low stage of heat.
The blower in cooling mode can be set to either a 5 second off time delay after the call for cooling ends, and defaults to a 90 second blower-off-time-delay after the call for cooling ends. The blower will ramp up gradually on the call for cool. The dip switches need to be set to match the tonnage of your condenser outside.
Also what kind of thermostat do you have?
gusherb94 is offline   Reply With Quote
Brand New Concord Furnace Doesn't Work In Cold Weather LeighC HVAC 21 01-07-2013 08:48 PM
Furnace venting questions Mastiff HVAC 9 12-05-2012 05:51 PM
Heil Furnace problem - is is the undersized vent? mpmusicny HVAC 8 11-20-2012 12:47 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
