Old 05-27-2012, 03:46 PM   #1
receiver driers with new coil?
Should the receiver drier be replaced when replacing a coil?
Thx
Slash
slash5bmw is offline   Reply With Quote
Old 05-27-2012, 05:31 PM   #2
Professional
The LIQUID LINE drier should be replaced when replacing a coil.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 05-28-2012, 12:06 AM   #3
I must agree... change the drier.....
carmon is offline   Reply With Quote
Old 05-28-2012, 02:31 AM   #4
REP
Its just good practice to replace the liquid line dryer whenever the system is broken open.
REP is offline   Reply With Quote
Old 05-28-2012, 10:41 AM   #5
Agreed with all of the above. The exceptions being if they had dry nitrogen flowing through the lines while the system was open or if the drier in in the condensing unit. In that case no moisture can get in so the drier would not need replaced.
Old 05-28-2012, 01:33 PM   #6
HVAC Tech/Owner
What "receiver drier" ? where exactly is the filter you are referring to located at?
Technow is offline   Reply With Quote
Old 05-28-2012, 02:32 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Id install/replace suction line dryer at same time if it were me
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 05-28-2012, 03:40 PM   #8
suction driers in my opinion are useless... unless you have had a bad burn you dont need one.... also a suction filter is not ment to be left in the sytem .They are to clean up acid and once they do there job they should be removed ......
Old 05-28-2012, 03:44 PM   #9
plummen's Avatar
Ok so you dont think theres a chance of whatever took the coil out being sucked back through the system into the condensor?
Old 05-28-2012, 04:34 PM   #10
newtech's Avatar
No.....
newtech is offline   Reply With Quote
Old 05-28-2012, 05:31 PM   #11
the coil either leaked.. or the drain pan rusted if its metal..not sure why coil being changed.... so I still say no suction scruber......
Old 05-28-2012, 09:48 PM   #12
manufactors provide them for a reason with some units....must be a good reason replace it with coil ....
Old 05-28-2012, 09:57 PM   #13
A suction drier..... I have never in 30 years been supplied a suction drier with a new unit.... a liquid line drier different story... good practice to install one....
Old 05-29-2012, 05:29 PM   #14
newtech's Avatar
Show me a MFG that supplies a SFD with a system
Old 05-29-2012, 09:25 PM   #15
one comes to mind payne by carrier.... we are talking about liquid line drier....right...
Evaporator Coil Sizing kandykane19 HVAC 0 05-05-2010 04:44 PM
Receiver upgrade - Audio wiring question jpb007 Home Theater 3 03-05-2010 05:53 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
Air conditioning coil heat tolerance? Badfish740 HVAC 1 10-19-2009 06:39 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
