-   -   receiver driers with new coil? (http://www.diychatroom.com/f17/receiver-driers-new-coil-145033/)
slash5bmw 05-27-2012 02:46 PM
Should the receiver drier be replaced when replacing a coil?
Thx
Slash
hvactech126 05-27-2012 04:31 PM
The LIQUID LINE drier should be replaced when replacing a coil.
carmon 05-27-2012 11:06 PM
I must agree... change the drier..... :no:
REP 05-28-2012 01:31 AM
Its just good practice to replace the liquid line dryer whenever the system is broken open.
Marty S. 05-28-2012 09:41 AM
Agreed with all of the above. The exceptions being if they had dry nitrogen flowing through the lines while the system was open or if the drier in in the condensing unit. In that case no moisture can get in so the drier would not need replaced.
Technow 05-28-2012 12:33 PM
What "receiver drier" ? where exactly is the filter you are referring to located at?
plummen 05-28-2012 01:32 PM
Id install/replace suction line dryer at same time if it were me :)
carmon 05-28-2012 02:40 PM
suction driers in my opinion are useless... unless you have had a bad burn you dont need one.... also a suction filter is not ment to be left in the sytem .They are to clean up acid and once they do there job they should be removed ......
plummen 05-28-2012 02:44 PM
Ok so you dont think theres a chance of whatever took the coil out being sucked back through the system into the condensor?:whistling2:
newtech 05-28-2012 03:34 PM
No.....
carmon 05-28-2012 04:31 PM
the coil either leaked.. or the drain pan rusted if its metal..not sure why coil being changed.... so I still say no suction scruber......
ben's plumbing 05-28-2012 08:48 PM
manufactors provide them for a reason with some units....must be a good reason replace it with coil ....:yes::yes::yes:
carmon 05-28-2012 08:57 PM
A suction drier..... I have never in 30 years been supplied a suction drier with a new unit.... a liquid line drier different story... good practice to install one....:no::no::no:
newtech 05-29-2012 04:29 PM
Show me a MFG that supplies a SFD with a system :whistling2:
ben's plumbing 05-29-2012 08:25 PM
one comes to mind payne by carrier....:yes: we are talking about liquid line drier....right...
