REALLY Hot Duct. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 08:05 AM   #1
PoleCat's Avatar
Rewards Points: 1,652
REALLY hot duct.
The ducts coming off the back of the plenum are almost too hot to hold your hand on while the ones on the front are only warm. Should I be concerned about this? Janitrol 70s vintage gas forced air furnace.
PoleCat is offline   Reply With Quote
Old 10-11-2012, 09:12 AM   #2
What do you mean by plenum? A plenum is basically a space meant to allow air flow.
I think you mean front and back of the furnace itself? If so, the hot ones are supply to the room and the warm ones are returns.
Too hot to hold starts at about 120F and paper burns at 451F so you're far from hazardous temps - unless the ducts are insulated and that's how hot the insulation is getting - then you're in trouble!
If the supply air is too hot then I'd suspect the air filter being clogged or too restrictive. The slower the air flows through your heat exchanger the hotter the air coming out will be so the less air your filter lets through the hotter the air will be.
How hot is the air blowing into your rooms?
pmeloy is offline   Reply With Quote
Old 10-11-2012, 05:46 PM   #3
PoleCat's Avatar
No, it is an up flow in the basement. Blower on the floor, firebox, a coil, plenum - metal box with four branchs going out from it at ceiling level. Return air goes into the bottem side of the blower enclosure. The difference in temperature from one side of this plenum to the other just seemed to be extreme to me. Sounds like it is a non issue though. Some outlets upstairs are hotter than others but not by that much.
Old 10-11-2012, 05:52 PM   #4
An old Tradesmen
Rewards Points: 7,816
Probably due to heat exchange design.
Repaired HVAC duct. What did I do wrong? What did I do right? SingleGuy HVAC 12 07-07-2012 02:12 PM
?an Insulated Flexible Duct - half attached and half unattached ? tran Roofing/Siding 2 06-21-2012 06:25 PM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 06:20 AM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
