Reaidential Duct Design
Ya I guess I was a little vague. The original ductwork has a subtle aroma of mildew and fuel oil from the original oilburner that was originaly in the house so I figured the only way to eliminate the problem and the fact that some of the registers arent getting the proper cfm's would be to replace the entire system. Minus the furnace that is 2 seasons old 60000btu mid efficiency Luxair.Bottom line what I need is PTO size,main trunk, return,and branch lines the longest being the branch that runs from the crawlspace to the top floor about 20ft which comes rate off plenum take off and roughly 8, 10ft takeoffs evenly spaced down the length of the main supply trunk.
