Re-sizing Heating Ducts - HVAC - DIY Chatroom Home Improvement Forum
Old 09-30-2007, 05:50 PM   #1
re-sizing heating ducts
I own a split level and am in the process of finishing the laundry room. The furnace is in this room also, and the duct work is exposed below the upper floor joists. I want to resize the duct work to fit in between the floor joists to save ceiling height. The existing duct work is 6" X 19". I want to resize it to 8" x 141/2" to fit between the joists, then reattach to the existing 6" x 19" when it transitions down the wall at the far end of the room. Is this something I can do without causing any restrictions in the system?
Dave B.
david belletsky is offline   Reply With Quote
Old 10-04-2007, 07:12 PM   #2
How long is the run?
redline is offline   Reply With Quote
Rehab Mess- Ducts Knocking-Furnace Vibrating drmark7 HVAC 7 03-18-2007 05:34 PM
Soffits for Heating ducts handyflyer Remodeling 5 02-06-2007 06:07 PM
How far should insulation be from heating ducts... AllGoNoShow Remodeling 4 11-09-2006 06:47 PM
Using PVC ducts instead of standard ducts robertmazzo HVAC 3 10-05-2006 05:26 PM
