Re-routing Ductwork. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 07:50 AM   #1
Re-routing ductwork.
Please see image for my current ductwork setup in my 1500 sq foot bungalow. The duct work that you see is all of the ductwork in the ceiling of the basement (feeding the main floor of the house).
I have a few issues, but my main issue is Trunk 2 (the one that goes to the back of the house. Because of where it punches through the wall, it causes a really ugly bulkhead scenario. What I'm wondering is if Trunk 2, could actually come off of Trunk1 further up the line, somewhere between line A and B? And then, I would run the trunk 2 through the wall and back down to finish where line H is. Would I leave the Trunk 2 at the size that is is now in that scenario?
Alternative idea (if it would work) is, could I punch lines E through H right off of Trunk 1 without the need for Trunk 2 at all?
I'm planning on finishing my basement in the near future, and would like to eliminate as many bulkheads as possible.
Thanks.
sc1977 is offline   Reply With Quote
Old 01-25-2012, 11:54 AM   #2
I'll let some of the experienced guys chime in but my first thought on either of your alternatives is that it will work poorly because trunk 1 may not be sized well enough to merely add in E, F, G, and H.
Also, do you have dampers on the takeoffs for runs A. B. C, and D?
Do you ever think you may zone your system?
An alternative; can you move trunk 2 to the left of the wall along trunk 1 and then punch through the wall for each of the runs?
That would leave trunk 1 entirely intact.
Rewound98 is offline   Reply With Quote
Old 01-25-2012, 12:59 PM   #3
There are dampers only on one of the lines for some reason (Line D).
Your idea of moving the trunk on the left side of the wall is not a bad idea (since the left side of the wall is crawlspace). Something to ponder.
Old 01-26-2012, 06:11 PM   #4
Rewards Points: 70
Just curious, which way do the joists run?
Dog5 is offline   Reply With Quote
Old 01-26-2012, 06:25 PM   #5
Experienced
Jackofall1's Avatar
How long is trunk #1? Why not just have it refabricated to the size need to feed both sides of the wall.
The Following User Says Thank You to Jackofall1 For This Useful Post:
sc1977 (01-31-2012)
Old 01-26-2012, 07:10 PM   #6
I'm Your Huckleberry
Rewards Points: 2,270
Why not a supply plenum with individual duct runs to each register? I count a total of 8 drops which is feasible on your average 3' supply plenum if you can use at least three sides. You stand a much better chance of each room receiving the right amount of air. Plus you can install a single damper for each run at the plenum itself.
You can possibly even use a few y's. That's what I would do.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
sc1977 (01-31-2012)
Old 01-31-2012, 07:21 AM   #7
The joists run from the front of the house to the back of the house.
And yes, to the other reponses. Perhaps, just refabricating the main trunk to a larger size would be the answer as it is about 17 ft long. I'll have a professional HVAC person come out and measure. Just thought I'd get some background info first.
Thanks to all.
Would like to Reduce one length of Ductwork? AlmondJoy HVAC 5 11-09-2011 09:12 AM
A/C and Ductwork Efficiency Jessidog HVAC 1 07-29-2011 07:48 PM
Ductwork Insulation tk3000 HVAC 3 11-19-2010 04:08 PM
plastic ductwork vs. metal: acoustic duct liners jjpclev HVAC 5 02-26-2010 07:29 PM
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 03:11 PM
