Re-routing Cold Air Returns - HVAC - DIY Chatroom Home Improvement Forum
Old 09-29-2007, 01:41 PM   #1
Re-routing cold air returns
Hi, I'm an HVAC newbie.
I am developing my basement and need to bring the cold air return (currently installed between the ceiling joists as are the heating ducts/vents) down to the floor level. This is an after thought following framing of partition walls and electrical. The current construction of cold air returns is using a plastic (?) thin corrugated board spanning two joists, thin silver cardboard barriers at the ends with grates installed in the plastic board. The new configuration of my basement is such that bringing the cold air returns to the floor in a straight line from the current channel is not an option.
Is it OK to 'T' off of these plastic board channels with metal ducting into one of the chnnels formed by the 2x4 studs in the aritions walls? I will need to actually turn about 180 degrees (2 x 90 degree elbows) from the original flow direction with this ducting. Does the flow direction matter or do you just need some sort of flow path for return air?
fjmb031507 is offline   Reply With Quote
Old 10-04-2007, 07:15 PM   #2
The least amount of turns is always best. Keep the size the same.
redline is offline   Reply With Quote
Old 10-05-2007, 11:07 PM   #3
Thanks Redline. So if I have to I can use large diameter metal ducting to connect the new cold air runs from the original run? I take it by "the same" size" you are reffering to the size of the intake vent or the intake duct (or both?)?
Thanks again
What is cold room for? KUIPORNG Remodeling 4 04-26-2007 06:06 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
Reducing size of very large air-vent returns in floor? AllGoNoShow HVAC 3 09-19-2006 10:36 PM
how cold is too cold for vinyl siding? THEBIGPUNN Building & Construction 1 11-22-2005 11:50 PM
Cold air returns (or lack thereof...) Umby HVAC 7 07-06-2005 11:24 AM
