Re-location Ducts With A New System - HVAC - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 09:49 PM   #1
Renovating My Land Yacht
Rewards Points: 616
Re-location ducts with a new system
Below is a pic of the living room in the house.
The unit is properly sized and they did the manual J etc. Just working on the ducting and the red x shows the current location of the two air registers in the ceiling.
The room faces the west so It does get warm in the afternoon in the summer. Does it make more sense to re-locate the ducts to where the green x's are on the warmer side of the room or would it not make much difference? Would I gain anything with respect to keeping the room cooler.
Thanks Robyn
forcedreno2012 is offline   Reply With Quote
Old 04-23-2013, 10:53 PM   #2
An old Tradesmen
Rewards Points: 6,112
Adding a supply between the 2 green X's would probably help more then just moving the existing.
The Following User Says Thank You to beenthere For This Useful Post:
forcedreno2012 (04-24-2013)
Old 04-24-2013, 12:55 AM   #3
Experienced HVAC Tech
HVAC1000's Avatar
where are your return airs in that picture?
HVAC1000 is offline   Reply With Quote
Old 04-24-2013, 01:43 AM   #4
Rewards Points: 616
Beenthere..not sure if we can add another run to make it three in there as we would mess with the manual J I think? Wouldn't that add to the cfm's? right now its sized for two 7 inch ducts.
HVAC the return air is to the right of the red x on the right side. is basically parallel to them on the floor.
Robyn
Old 04-24-2013, 01:57 AM   #5
I'm Your Huckleberry
Rewards Points: 2,270
bullhell. a manual j just satisfies what a room's cfm should be. how it's delivered is up to the contractor.
keep supply grills close to the inner wall, vents blowing towards the window to fight the heat load.
btw, if you get three different contractors to perform three different manual j's, you'll get three different results. good luck, I hate conversations of this matter.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 04-24-2013, 02:09 AM   #6
Rewards Points: 616
I hear you Doc on the issues and the discussions - try getting quotes on different units and its crazy. And don't even ask why one unit is better than the other .
I started researching and at one point said bugger it, I'm not getting the HVAC replaced...that of course was before it got warm .
I am grateful for all the advice here though, it has saved me some time and led me to get rid of some definite shysters and we have a great installer now, local team and they have been very accommodating for us.
Soooo back on topic, it sounds like from the answers so far I would not gain much by moving the vents, which I am okay with - it was a thought I had (happens now and then) before I tore the old stuff out and ran the new.
Robyn
Old 04-24-2013, 04:41 PM   #7
An old Tradesmen
Do any of your other rooms/areas have a problem cooling. If not, loosing a little air to those areas won't hurt anything.
A strange one - polybutelene piping used in radiant heating system GordCooper Plumbing 4 03-13-2012 11:09 PM
Need Help Buying a Sediment and Water Softener System. vpr80 Plumbing 10 02-23-2012 11:26 AM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
