Rattling Pipes When Water Heat Exchanger Stops - HVAC - DIY Chatroom Home Improvement Forum
Old 04-06-2009, 10:15 AM   #1
Question
rattling pipes when water heat exchanger stops
My central AC unit exchanges heat from well water, when automatic sensor shuts down the exchange, once set temperature reached, the water flow is stopped by an irrigation valve activated electrically.
The sudden stop of the flow makes the pipes rattle and has caused breaks flooding the space. I was advised that a "throttling valve", instead of the irrigation valve, will gradually stop the flow preventing the sudden stop. However, I can,t locate such a valve.
I would appreciate any comments regarding where to locate the part and/or its effectiveness. Also, the alternative of installing a small pressure surge tank.
Amilcar is offline   Reply With Quote
Old 04-06-2009, 12:38 PM   #2
An old Tradesmen
Rewards Points: 6,132
You mean like this
Old 04-06-2009, 03:44 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,140
http://www.taco-hvac.com/en/products...s/contact.html
Try contact these guys, they make lots of different valves, expansion tanks and may be able to help.
Good Luck
Why do water heaters have two elements? gp_wa Plumbing 21 02-09-2012 02:56 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
water dripping from heat vents pamleo HVAC 8 01-28-2009 10:40 PM
I hear the water running in my heating pipes CMG HVAC 3 12-08-2008 07:46 PM
Tankless or tank, but not both gp_wa Electrical 43 10-15-2008 11:08 PM
