-   -   rattling pipes when water heat exchanger stops (http://www.diychatroom.com/f17/rattling-pipes-when-water-heat-exchanger-stops-41904/)
Amilcar 04-06-2009 10:15 AM
My central AC unit exchanges heat from well water, when automatic sensor shuts down the exchange, once set temperature reached, the water flow is stopped by an irrigation valve activated electrically.
The sudden stop of the flow makes the pipes rattle and has caused breaks flooding the space. I was advised that a "throttling valve", instead of the irrigation valve, will gradually stop the flow preventing the sudden stop. However, I can,t locate such a valve.
I would appreciate any comments regarding where to locate the part and/or its effectiveness. Also, the alternative of installing a small pressure surge tank.
beenthere 04-06-2009 12:38 PM
You mean like this
yuri 04-06-2009 03:44 PM
http://www.taco-hvac.com/en/products...s/contact.html
Try contact these guys, they make lots of different valves, expansion tanks and may be able to help.
Good Luck
