Rated EER - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2012, 06:22 PM   #1
Rated EER
I am trying to find the EER of an entire list of units. I have make and model#s. Most are older units, but I am having trouble finding them. Does anyone know of any websites I can use to search for their rated EERs?
kaylaroz12 is offline   Reply With Quote
Old 09-21-2012, 07:01 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Rated EER
Google search the condenser brand nomenclature.
Example: Bryant Nomenclature
http://literature.cwgoodguys.com/123A-Spec.pdf
Scroll down just under the first picture of the unit to the top of the second page and look at the Model Number Nomenclature. The third number from the far left is 3 which means 13 seer. It's explained.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 09-21-2012, 07:06 PM   #3
Rewards Points: 588
Rated EER
First you should try searching the web with title of SEER not EER the S is for seasonal...you will find various lists of SEER ratings for various makes and types of units..hope this helps
techpappy is offline   Reply With Quote
Meaning of Recessed Lights That Are "Not Rated for Insulation"? DoItY Electrical 7 06-30-2012 01:00 AM
125 amp rated breaker panel yet I have 155 amps worth of breakers??? graysqwrl Electrical 3 08-28-2011 03:25 PM
Fire Rated Plywood cwatts50 Building & Construction 8 08-07-2011 05:48 PM
Structured Wiring Panel Location...Fire Rated Wall??? RICKM15752 Electrical 0 04-20-2011 12:30 PM
Non-IC rated lighting in Insulated cieling. OOPS! MyMonkey Electrical 7 02-22-2008 10:46 PM
