Old 08-14-2012, 04:17 PM   #1
Range hood install
Hello all. Im putting in the 6" round ductwork for a range hood. It will be going through the wall into the garage attic and up out the roof. I could use some advice before i get going. First, the duct pipe will be slightly in contact with a copper heating pipe that runs along the wall. Theres no way around it. What would be the best buffer to put between them? Second, should the pipe run downhill a bit from the hood just in case water gets inside it doesn't flow back to the unit. And last, what is the best way to seal around the pipe at the wall? I researched all this on the net but couldn't find too much info. Thanks for any help.
Zephyrg is offline   Reply With Quote
Old 08-14-2012, 10:08 PM   #2
Bchill
Range hood install
Hire a Professional who is insured, I wouldn't take the risk if anything goes wrong and your not licensed your insurance won't cover you.
Affordable Comfort, assisting with
and surrounding area, as well as offering 24 hour
Acomfort is offline   Reply With Quote
Venting Range Hood - Straight Up? Thadius856 Remodeling 4 08-05-2012 01:37 PM
Kitchen Range Hood Tryon HVAC 2 04-01-2012 06:01 PM
Problems with range hood installation. darsunt Remodeling 9 01-06-2012 05:59 PM
Range Hood Ducting go Down? jerryk1234 Kitchen & Bath Remodeling 15 09-22-2011 11:10 PM
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 07:19 AM
