Old 12-11-2012, 04:13 PM   #1
range hood ductwork
Hello, I've got a few minor issues that I need help on. I recently had a new kitchen range hood installed. There was none previously except for a really old ceiling fan that exhausted back into the attic (I never understood the lack of wisdom behind such a design/device). The house is built 1950. The handyman that I hired cut a square hole into my ceiling through which to run the ductwork but now there is gap between the square hole and the round duct. I know this is not right but he's long gone. How do I seal up this gap in the ceiling, between kitchen and attic? I've seen in other properly done kitchens that there's a round metal plate that goes around the duct, forming such a seal.
From the attic upwards the duct goes straight through another square hole in the roof. I had a professional roofer install the roof vent, but he didn't touch anything else other than install the roof vent. So again, there's a square whole in the roof (over which the roof vent covers) and the round duct and gap all around. Does this gap also need to be sealed and if so, how?
Thanks!!!
redleader is offline   Reply With Quote
Old 12-11-2012, 04:16 PM   #2
range hood ductwork
Got some pictures?
Old 12-11-2012, 04:18 PM   #3
range hood ductwork
Thanks for the fast response. I'll get some pictures posted up tonight.
I have a 1955 home and am finding all sorts of little things that need fixing; jobs that are too small for a licensed contractor to deal with but if I were to hire a handyman I'd rather learn to do it myself.
Old 12-11-2012, 04:44 PM   #4
range hood ductwork
Should be as simple as cutting out a piece of sheetrock to cover up the hole in the attic and add insulation over it.
As far as the roof he should have cut out a 2' X 2' patch to go under the shingles with a round hole in it for the vent.
Old 12-11-2012, 04:48 PM   #5
range hood ductwork
Ok, i've attached a diagram of what I'm talking about.
Old 12-11-2012, 04:54 PM   #6
range hood ductwork
I know what your talking about, but needed to see just how big the gap it.
Old 12-11-2012, 05:15 PM   #7
range hood ductwork
No problem, I'll post actual photos tonight...Thanks!
Old 12-11-2012, 11:16 PM   #8
range hood ductwork
Ok, photos attached. You can see what a poor job this one. First of all, the wiring is completely not to code and to just thread it right through the big hole that was cut. Anyway, you can see what I mean regarding the square opening leaving big gaps. I know it's not suppose to look like this. There's also a photo of the square opening cut into the roof and the way the duct goes up into it. So, I want to fix this hack job on my own rather than paying someone to do it. Although, I will have an electrician redo the wiring.
range hood ductwork-sm_img_0863.jpg   range hood ductwork-sm_img_0865.jpg   range hood ductwork-sm_img_0868.jpg   range hood ductwork-sm_mg_0779.jpg
Old 12-12-2012, 12:24 AM   #9
range hood ductwork
If I had to fix that I would measure the width and length needed, cut a piece of sanded 1/4 plywood to size.
Take measurement from the edge of the face frame of the cabinet to the edge of the pipe, mark my piece of wood, find the center and make an X. Then use a hole saw to make the hole, no 4" hole saw then you can use a compuss to make the circle and use a jig saw.
Stain and seal it.
Remove the pipe, remove that cove moulding in the back of the cabinet and install the new piece.
Some PL adhesive should hold it in place.
Reinstall the cove and the pipe, use foil tape at the joints.
Old 12-12-2012, 07:10 AM   #10
range hood ductwork
They manufacture sheet metal things called bases/guides that class B pipe and smoke pipe pass through partitions and roofs they are square with a round hole in the middle that the pipe goes through.
The reason is to keep hot pipes 1" away from combustible materials.
A square hole is cut and the base/guide is nailed in place then as the pipe is assembled its passed through the base and held in place with tabs or straps.
Then you are assured the heat is away from combustible material and won't dry it out over the years.
I know they are used for heater flues I don't know if it's required on hood vents.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Installing a range hood with existing ductwork dave.vp HVAC 2 11-10-2012 01:41 AM
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 07:19 AM
Can NM come in contact with ductwork from residential kitchen range hood? northstar1 Electrical 2 12-13-2010 11:47 AM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 08:00 PM
Questions about ductwork for kitchen range hood ilyaz HVAC 11 12-09-2009 01:16 AM
