Radiator Removal
They make rad's that you can place against the floor. They use a reflective surface to keep the heat going up, instead of out. But usually it is PEX that is used, since it is easier to use, and allows for more and better heat transfer.
When you do this, if you do not already have, you may want to look into zoning, along with a thermostat to control the temp to the bath.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
