-   -   Radiator Problem (http://www.diychatroom.com/f17/radiator-problem-55199/)
yanks2009 10-14-2009 10:25 PM
Radiator Problem
Hi everyone.
My heating system is kind of unusual. I have hot water baseboard on my first floor, 5 radiators on the second floor and one radiator in the attic.
I recently had the boiler serviced and have started using the heat. The baseboard on the first floor work fine.
Two radiators on the second floor and the radiator in the attic are also working. However, three of the radiators on the second floor remain cold.
I cannot easily bleed the radiators on the second floor because there aren't any bleed valves and the screws where the bleed valves would go are painted over. Obviously, it is unlikely the prior owner bled them. Also, because the radiators are totally cold, I don't know if bleeding will help. All of the radiators have automatic air vents (they appear to be fairly old). I did notice that the radiators made whistling noises (through the air vents) at times but did not warm up at all.
Any thoughts as to what the problem may be? Thanks!
SKIP4661 10-15-2009 12:00 PM
Is this a hot water system or steam.
Scuba_Dave 10-15-2009 12:09 PM
If they have air vents they should be steam
Are there multiple runs
IE the non-heating radiators are on their own pipe run?
One house I saw the pipes were so clogged that steam could not get thru
yanks2009 10-15-2009 12:19 PM
Thanks for responding. The baseboard on the first floor is hot water baseboard and the radiators on the second floor are steam...does this make sense?
