Radiator Boiler (gas) Spiral Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 03:04 AM   #1
Rewards Points: 1,062
Question
radiator boiler (gas) spiral venting
in the old setup in the basement, shown in the picture, my gas radiator boiler had some spiral venting right above it before it went some 7-8 ft in gentle gradient up to the chimney and then two full floors up to the roof.
i am moving it to the first floor and was wondering whether i need a similar spiral in the same position. the boiler is about 34" high and the vent makes the first 90 turn in the ceiling above it at about 100", then it goes 8 ft, 90 turn, goes 5 ft and into the chimney going one full floor to the roof.
so i thought perhaps due to a different setup, i wouldn't need this spiral thing. don't know ... obviously, it is cheaper and simpler without it, especially because i have to order type B venting cause all the stores in my area that sell it require an HVAC license in order to sell it.
thanks
Old 09-21-2011, 12:02 PM   #2
fabrk8r
fabrk8r's Avatar
If you're talking about the aluminum flex duct (flexible dryer vent pipe) in the picture, that isn't "spiral" pipe.
This is spiral pipe......it's rigid.
BTW, why are there 4 90 adjustable ells coming off the top of the boiler when 2 would suffice?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-21-2011, 12:54 PM   #3
Question
i thought the spiral in spiral vent was referring to the spiral formation the ells made, not the shape of the pipe itself. i was asking the same question, why is there the curl coming out of the furnace when two or possible even a single ell would suffice but then i was told it's a "spiral vent" without much further explanation.
basically, do you think i can just have a straight pipe coming out of the appliance to the first 90 deg bend in the ceiling? i really don't see why not but someone else made me nervous and, since it's CO that's at stake, i didn't wanna prove myself wrong dying.
Venting ponch37300 Plumbing 41 02-23-2013 11:37 PM
Venting and insulating 1 1/2 story helgymatt Roofing/Siding 1 02-22-2011 07:58 PM
Need Help Replacing Spiral Blades on Snow Thrower cynergyou General DIY Discussions 3 01-22-2011 09:53 AM
Venting a sink pump WillK Plumbing 2 12-26-2010 02:21 PM
Gas furnace venting Qs (non high eff) WallyWoggle HVAC 6 12-09-2010 07:41 PM
