Radiant Heating - HVAC - DIY Chatroom Home Improvement Forum
Old 12-22-2009, 09:50 PM   #1
Solutions (handyman)
Rewards Points: 362
Radiant Heating
I currently have radiant heating under my basement concrete. The hot water goes directly from my oversized water tank through my system and back to the tank. One pump does it all. Would I be better off to add a second pump and a heat exchanger? Is there much benefit or is it an extra cost that I might not benefit from for a while? Any advise would be appreciated. By the way, I reside in northern Alberta, Canada, so cool weather can be a factor.
Thanks.
Mark Harvey is offline   Reply With Quote
Old 12-22-2009, 10:26 PM   #2
An old Tradesmen
Rewards Points: 6,124
Second pump and heat exchanger will just lower the efficiency. So no pay back. Just added cost.
Old 12-23-2009, 05:36 AM   #3
Too Short? Cut it Again!
If it ain't broke and is working well, don't mess with it. I agree you gain little by adding an additional pump and exchanger.
Old 12-23-2009, 11:49 AM   #4
Rewards Points: 362
Thanks for the input. Merry Christmas.
Wanna help design a hydronic radiant heating system? YerDugliness Green Home Improvement 4 05-03-2009 11:10 AM
using forced air for radiant heating djsmith9 HVAC 22 10-30-2008 10:50 AM
radiant heating floor system/PEX/water heater mudpaw HVAC 12 08-19-2008 04:29 PM
Radiant floor heating info? TonyGG Building & Construction 5 06-17-2008 11:56 AM
Radiant Heating on Cement Slab can'tdecide Flooring 2 08-21-2007 01:59 PM
