Radiant Heat Vacation Mode - HVAC - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 09:01 AM   #1
Rewards Points: 79
Daughter and son-in-law just purchased a home and it has a oil fired boiler that provides radiant heat and hot water for the home. Son-in-law deployed and the system is in waht the previous owner (85 year old widow whose husband took care of all of the home chores) has no idea of hopw to take the boiler off of the vacation mode and put it back in a normal mode (all beyond my knowledge level). Anyone have a clue before we call a conrtator in?
vabear is offline   Reply With Quote
Old 05-18-2011, 01:36 PM   #2
biggles's Avatar
if the stat has sleep/wake/leave/return settings it just higher temperature adjustments to correspond to the new owners day/night
Old 05-18-2011, 03:04 PM   #3
Rewards Points: 79
Radiant Heat
Thank you, I suspected the "T" Stat was involved, will check that out.
Old 05-18-2011, 04:41 PM   #4
An old Tradesmen
Rewards Points: 7,826
Could be a Buderus, if it is, the boilers control has the vacation mode. Look to see what brand boiler it is.
Old 05-18-2011, 06:06 PM   #5
Rewards Points: 79
Boiler
Will Do.
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 09:27 AM
Replace forced air heat vent with radiant floor malfunction HVAC 9 02-05-2009 12:01 PM
Installing pex radiant floor heat, questions. iMisspell HVAC 27 01-15-2009 07:03 PM
Insulate joist bays along with radiant heat, how ? iMisspell Building & Construction 2 12-08-2008 12:17 PM
