Radiant Heat Under The Tub - HVAC - DIY Chatroom Home Improvement Forum
Old 04-06-2010, 08:42 PM   #1
Radiant heat under the tub
I had an engineer do the pipe layout for my in-floor heat and I noticed he didn't put any piping under the tub. Should there be some so that when you get in, the floor of the tub is warm or would the heat not transfer to the tub.
mugen is offline   Reply With Quote
Old 04-06-2010, 09:12 PM   #2
Rewards Points: 292
That is not typically done. The tub would trap more of that heat than it would transfer. Tubs normally go directly onto the subfloor. Radiant heat systems go under a finished floor.
Jim F is offline   Reply With Quote
Old 04-06-2010, 09:23 PM   #3
Agreed, usually radiant heat is not installed under fixtures, cabinets etc
Old 04-07-2010, 06:18 PM   #4
Thanks for the info. Since I have an engineered drawing showing the location of the pipes is this something I should attempt myself or would there be any benefits to paying the extra cost of hiring a professional to do it.
Old 04-07-2010, 07:27 PM   #5
Rewards Points: 292
I think it depends on your level of confidence and ability. I would definately read all I could about installing the system befor attempting it. From what I have seen they use PEX which is relatively user friendly and have slots that hole the tubing at the proper spacing.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Radiant floor heat question. ingeborgdot Remodeling 6 03-23-2010 12:05 PM
Radiant Heat and Tile Texasguy HVAC 5 04-07-2009 10:14 AM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 01:17 PM
