Radiant Heat Issues - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-06-2013, 05:51 PM   #16
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
Further, depending on the size of the circuit feeding your existing floor warming system and how much it is drawing from it and how much more you add below, you MAY be able to have them both on the same circuit so that the existing GFI tstat runs them both.
The suggested installation/insulation is as follows:
Staple the Calorique element 1" down from the plywood subfloor and make your connections, then staple a reflective insulation face up 2" down from the Calorique film element and, if you have the room, add fiberglass insulation below the reflective. This will give you the best design to get the maximum use of the retro-fit radiant from below.
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Old 02-06-2013, 06:48 PM   #17
Rewards Points: 252
Thanks all. Ripping out the tiles and mud job isn't an option - unless I want the wife to leave me=)
I like the idea of filling in the cold spots with electric radiant from below (the existing floor heat is on its own 20a circuit so I do have the room there). My concern would be -will the staple up radiant make its way up through a 1" mud job and another 1/2" or so of tile and thinset? Even if it did warm p the floor In those spots, i would have to supplement the floor heat with a baseboard radiator.
I'm not opposed at all to putting in hydronic radiant under the entire floor. I was thinking of installing the hydronic radiant under the subfloor using those aluminum plates, then insulating under all that, and then installing a runtal baseboard heater in the room as well. I have a plumber coming tomorrow to look at everything. After my first experience I would like to try to figure out the btus needed to heat the room so I can size the radiator appropriately.
mazzonetv is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Radiant Heat in a Detached Garage jmorganix HVAC 3 02-08-2012 06:06 PM
Radiant Ceiling heat from 1960's donfranko HVAC 2 12-09-2011 06:19 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
