Radiant Heat - How To Route Or Melt XPS For Pex Channels - HVAC - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 05:28 PM   #1
Rewards Points: 143
Question
Radiant Heat - How to Route or Melt XPS for Pex Channels
Hi everyone,
I am in the middle of a DYI radiant heat install. I have plans from my radiant guy. In the basement in order to prevent heat loss to the slab I was told to put down 2" of XPS then using a sleeper system lay my pex and then tile on top.
The overhead in the basement is tight and I had an idea. Instead of using sleepers, I thought making the channels in the XPS directly and then put osb or 1/4 cement board on top would be smarter. Yes 1/2 inch would make a difference.
Hoping to get some feedback on my idea and how to possibly get it down. As far as the channels, I could route the channels by hand or I was thinking of using a copper pipe and maybe heating it up and somewhat melting/molding the channels.
cloves is offline   Reply With Quote
Old 03-12-2013, 05:42 PM   #2
Rewards Points: 13,446
XPS gives off toxic fumes when it burns or melts.
http://www.warmboard.com/
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Radiant Heat in a Detached Garage jmorganix HVAC 3 02-08-2012 06:06 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Radiant heat and asbestos tiles sixsix General DIY Discussions 2 07-23-2010 09:00 AM
Replace forced air heat vent with radiant floor malfunction HVAC 9 02-05-2009 12:01 PM
