Old 12-08-2007, 09:05 AM   #1
radiant heat in basement
I am installing radiant heat in my home. According to the instalation instructions for a basement slab I have to put down 1 inch foam insulation first on the dirt floor. Do I have to do this. I am on a tight budget and this will cost an extra $850.00. Are there any alternatives?
plgrm is offline   Reply With Quote
Old 12-08-2007, 06:10 PM   #2
No. If you don't insulate the dirt, you'll be pumping heat into it, and would have to double the amount of radiant to compensate. Then your next post will be "the radiant heat I installed under my basement floor w/o insulating first isn't heating my basement too well, and my utility bills are out of this world. What can I do to raise the temperature and lower my bills?"
What's ironic about your question is that you've got the money to heat your basement at ALL - but you claim a "tight budget."
LawnGuyLandSparky is offline   Reply With Quote
Old 12-09-2007, 07:41 AM   #3
FatAugie's Avatar
If you think about it, is there ever a person who says "Money is no object, I don't care what it costs...go ahead". You'd know that person by the line of contractors at his house stretching around the block.
Cost is always a concern, but I agree that being penny wise and pound foolish at this stage is a not a good idea. I'd bet 2" of foam would be even better, but that's where you get into cost/benefit analysis. $850 is probably chump change for the total cost of the project.....don't go cheap now.
FatAugie is offline   Reply With Quote
More On This Topic
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Now we are going to be doing a song that we have been working on and it involves some hand motions choreography. Ready? The wise man built his house upon the rock, the wise man built his house upon the rock, the wise man built his house upon the rock and... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip, I'll be installing the foam sleeve. Now to pick up dust and dry material, we have to install a foam sleeve and a dry filter and this is going to insure proper filtration. Next we need to... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Laminate in Basement over Hydronic Radiant Heat art2670 Flooring 3 10-12-2007 11:17 PM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 01:52 PM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 02:17 PM
Radiant Heat Flooring As Only Heat Source? digthisbigcrux Building & Construction 2 03-10-2007 12:33 PM
Finishing Basement, How to run a heat duct? hyper Remodeling 6 02-23-2007 04:46 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
