Radiant Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 10:51 PM   #1
radiant heat
I have a 1500 sq ft ranch on a slab. It has a forced air furnace now w/ducts in the slab. I'm not really a fan of the forced air system and I'm toying with the idea of radiant hot water heat. Is there products out that I won't have to bust up the concrete or add a top coat? I really don't want to raise the floor a lot and I don't want baseboard.
How well does this type of heat work under carpet? Does it have adverse affects on hardwood (drying it out and shrinking it)?
How do I figure boiler size, or will a tankless heater work?
If it's true that you learn from your mistakes- I'm getting one heck of an education
thumbkins is offline   Reply With Quote
Old 01-26-2009, 05:59 AM   #2
An old Tradesmen
Rewards Points: 6,092
Do a heat loss calc, and that will tell you how big of a boiler you need.
Old 01-26-2009, 06:56 AM   #3
biggles's Avatar
chech out here for some ideas www.wattsradiant.com
Installing pex radiant floor heat, questions. iMisspell HVAC 27 01-15-2009 08:03 PM
Questionable radiant heat installation jzinckgra HVAC 3 05-30-2008 08:55 PM
Radiant heat question tpagel HVAC 4 05-21-2008 05:57 PM
radiant heat in floors What have I done HVAC 2 11-12-2007 11:59 PM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 02:17 PM
