Radiant Floor Rebuild - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 04:07 PM   #16
Home Air Direct's Avatar
Admittedly, I am not an active installer/tech contractor, but am a wholesaler by trade and I am not versed on residential code, so do not profess to have any advice on that. The projects that I have been involved in all were kinda out in the sticks (in the county) and codes be damned for most of these I guess.
I can design and spec and run loads, but am not in a position to advise on code, but if I were you, I would just call the local building code inspection entity and quiz them. Really a better idea then asking those of us who may be speaking from our own local perspective and/or a national code and not specific to your rules.
Good luck to you.
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Tags
basement floor rebuild , basement radiant floor , basement radiant rebuild , leaking radiant floor , radiant floor rebuild
steam v. hot water, radiant sub-system Lor HVAC 1 06-11-2009 04:58 PM
Radiant heat question tpagel HVAC 4 05-21-2008 05:57 PM
Radiant flooring question tpagel Flooring 7 05-21-2008 02:41 PM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 02:17 PM
radiant slab vs. overhead radiant tube holedpiston HVAC 2 05-09-2007 12:59 PM
