Radiant Floor Heating Questions - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-28-2010, 10:02 PM   #16
Just call me Andrew
Rewards Points: 1,020
Forgot my pic...
Andrew
secutanudu is offline   Reply With Quote
Old 02-28-2010, 10:16 PM   #17
An old Tradesmen
Rewards Points: 7,794
The circ for the radiant loop MUST pull through the mixing valve. And you will need flow checks.
Here is a quick drawing I made from a drawing I did for someone else. Its just a representative one. Doesn't have to have teh regular temp zone circ piped where this one is on the return.
Old 03-01-2010, 06:33 AM   #18
Just call me Andrew
Makes perfect sense, thanks.
In your drawing, where would you put in a high temp zone?
Andrew
Old 03-01-2010, 06:52 AM   #19
An old Tradesmen
High temp zone. is your rads, or copper baseboard.
Old 03-01-2010, 09:29 AM   #20
Just call me Andrew
I meant...where would you add it to the system? Just another circ pump with a loop off the hot feed?
Andrew
Old 03-01-2010, 02:04 PM   #21
Just call me Andrew
Originally Posted by warmsmeallup View Post
Only low voltage can be used in the shower. It's a waterproof element and ...low voltage.
What manufacturer do you recommend? I have a 5'x6' bathroom with a 3x3 shower, so 39 sq feet. Any estimate on how much the supplies would cost to heat a room that size with low voltage? Just one outside 6' wall that will have R13.
Andrew
Old 03-01-2010, 03:57 PM   #22
An old Tradesmen
It can be added to the supply line anywhere it doesn't interfere with water flow to the other zones.
Old 03-01-2010, 04:20 PM   #23
it looks like a 100ft roll of 1/2" oxy pex will do the job. I agree with been there on the layout. There's nothing special needed as long as you can get the right temp. supply into your radiant loop, which is typically 140F for the floors
Boler.J is offline   Reply With Quote
Old 03-01-2010, 07:23 PM   #24
Just call me Andrew
What about running the full 180 degree temp water and installing it between the floor joists in the basement with the reflective shield below it? Does that work well?
Andrew
Old 03-01-2010, 08:57 PM   #25
An old Tradesmen
Nope.
A. It becomes hard to control temp rise of joist cavities.
B. Tends to cause expansion problems with the pex.
C. Tends to dry out the wood too much. And if you have wood floors they will warp.
Old 03-02-2010, 05:50 AM   #26
Just call me Andrew
Darn. Maybe low voltage electric is the way to go. Hydronic seems awfully complicated (read: expensive).
Andrew
Old 03-02-2010, 06:04 AM   #27
An old Tradesmen
Definitely cost more to install.
Weather it cost more to use, depends on your areas electric rate, and your cost for gas/oil.
Old 03-02-2010, 06:06 AM   #28
Just call me Andrew
I also don't like my floor being raised up 3/4". How hot do the elements in a low-voltage system get?
Andrew
Old 03-02-2010, 07:55 AM   #29
I went with electric radiant line voltage for my bathroom & hallway outside the bathroom
For the cost of a heat matt I bought the wire & had enough to do thehallway too
I looked at the low voltage & it was quite a bit more - this was 5 years ago
NuHeat I think was one I looked at
Bathroom was too small for hydronic, sunroom would be nice ~250 sq ft
Old 03-02-2010, 10:23 AM   #30
Just call me Andrew
Nope.
A. It becomes hard to control temp rise of joist cavities. What do you mean by this?
An HVAC guy I know told me I can use something called "onyx" tubing to run the full 180 degree temp. I don't have hardwood floors, this will just go under the tiled bathroom.
Maybe i;m better off with a small 3' baseboard plus line voltage electric under the non-shower portions of the floor?
Andrew
Radiant Floor Rebuild kiwegan HVAC 15 02-20-2010 03:07 PM
Hydronic Radiant Floor install questions ink HVAC 9 01-10-2010 09:34 AM
steam v. hot water, radiant sub-system Lor HVAC 1 06-11-2009 03:58 PM
Installing pex radiant floor heat, questions. iMisspell HVAC 27 01-15-2009 07:03 PM
Radiant Floor Heat (ongoing questions) iGotNoTime HVAC 7 08-23-2007 03:55 PM
