Radiant Ceiling Heat... - HVAC - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 06:15 PM   #1
Question
Radiant ceiling heat...
Hello.....I just moved into a house that has radiant ceiling heat and I know very little about it.....my question is, after doing some online research, how can I safely mount things IN the ceiling like...a plug-in style ceiling fan, hanging lamps that require screw in ceiling hooks, etc. without damaging the wires or coils? Thanks to anyone who can help me with this!
ginger48 is offline   Reply With Quote
Old 11-29-2010, 09:59 AM   #2
Craftsman
There are two basic types, cable radiant heat installed between double thick drywall sheets by hand when the home was built (usually in older homes) and manufactured drywall panels with heat strips in bedded in them (70's and 80's). Cable systems were usually along the whole ceiling. Newer systems were one, two or three 4x8 sheets per room along the outside walls in warmer climates or more in cold climates. Their location can be identified by thermal imaging. Some home inspection companies can identify their location or if you are lucky enough to know who wired the house you could call them. Either way you need to be carefull, if nicked or cut you will lose heat in that room.
Superrick is offline   Reply With Quote
Tags
mounting ceiling fans , radiant ceiling heat
ceiling demolition with radiant heat jwenger Drywall & Plaster 5 10-23-2010 04:14 PM
radiant heat on cement slab alihawk Flooring 0 07-01-2010 05:23 AM
radiant floor heat over slab subfloor Terry68 Flooring 9 06-13-2010 05:58 PM
Covering Radiant Heat ceilings. Hockeynews Remodeling 3 04-10-2009 08:23 AM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 01:17 PM
