Radiant Boiler Flame - HVAC - DIY Chatroom Home Improvement Forum
Old 10-15-2009, 10:24 AM   #1
radiant boiler flame
thanks for looking i have a old montgomery ward gas boiler with radiant base board heat.i just replaced my pump now the flame will not fire the pilot will stay lit the pump spins i hear water flow the pilot was lit all summer please advise its getting cold in detroit
laenbro is offline   Reply With Quote
Old 10-15-2009, 10:45 AM   #2
An old Tradesmen
Rewards Points: 7,356
Did you turn the gas valve knob from pilot to "ON"?
Old 10-15-2009, 10:52 AM   #3
gas
yes i did after i held it for 60 seconds
Old 10-15-2009, 11:11 AM   #4
An old Tradesmen
May just be that the thermocouple is too weak to open the main valve.
Old 10-15-2009, 11:21 AM   #5
is that is the brass looking tube that burns above the pilot light
Old 10-15-2009, 11:23 AM   #6
An old Tradesmen
Brass looking tube that the pilot flame burns against.
Old 10-15-2009, 11:35 AM   #7
yeah the end looks pretty well covered in carbon.i thought i could be caused by trapped air i bleed the system twice .i thought i was saving money replacing the pump.
Old 10-15-2009, 11:38 AM   #8
An old Tradesmen
A bad circ, or air in the boiler/piping would not prevent the burner from working. It would just cause the boiler to reach its set te,p quicker. And still have no heat.
Old 10-15-2009, 11:48 AM   #9
how about dirt? is it likely that could be my problem
Old 10-15-2009, 12:13 PM   #10
An old Tradesmen
A dirty pilot could cause it.
Corrosion on teh thermocouple could cause it also.
Old 10-15-2009, 12:22 PM   #11
thanks im gonna get on it and see if i get it going
steam v. hot water, radiant sub-system Lor HVAC 1 06-11-2009 03:58 PM
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 08:48 AM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
Utica Boiler Pilot light on but will not flame up! MGB150HID HVAC 2 12-10-2007 04:48 PM
