R410a Disposable Cylinder Weight - HVAC - DIY Chatroom Home Improvement Forum
Old 06-03-2013, 10:44 PM   #1
R410a disposable cylinder weight
I was given a Dupont Suva R410a 25lb.disposable cylinder,I'm not sure how much refigeant is inside,does anyone know the empty weight,or way I can find out how many pounds of liquid are inside?
Br350obx is offline   Reply With Quote
Old 06-03-2013, 11:10 PM   #2
Rewards Points: 616
should be stamped on the tank.......
carmon is offline   Reply With Quote
Old 06-03-2013, 11:31 PM   #3
I see a "4" stamped on the handle at the tank,4lbs?
Old 06-03-2013, 11:34 PM   #4
Experienced HVAC Tech
HVAC1000's Avatar
hook up gauges to check pressure
HVAC1000 is offline   Reply With Quote
Old 06-03-2013, 11:35 PM   #5
Rewards Points: 616
not in my area ...... should saw TW then weight.... the old drums weighed about that..... that was years ago though... ...
Old 06-03-2013, 11:37 PM   #6
Rewards Points: 616
that will prove little ... he want to know how much is in the tank. ... what will the pressure prove
The Following User Says Thank You to carmon For This Useful Post:
Br350obx (06-03-2013)
Old 06-03-2013, 11:43 PM   #7
HVAC1000's Avatar
once all the liquid is gone and only vapor remains you can calculate how much is left using pressure and the temp of bottle.
Old 06-03-2013, 11:46 PM   #8
I want to know if it's damn near empty now or there is a few pounds in there,I want to know if I have enough to trim in my system,or do I have to get a new bottle.
Old 06-03-2013, 11:50 PM   #9
Rewards Points: 616
i here ya ... not sure the cylinder you have.... weight minus the TW is what is left.....
Old 06-03-2013, 11:53 PM   #10
HVAC1000's Avatar
you can either hook it up to your suction line and use your compressor and close the liquid line to pump down the cylinder until satisfied or you can call Du Pont and ask for net weight when empty
Old 06-03-2013, 11:56 PM   #11
I don't see a "TW" and then a number ,All I see is a 4 stamped in,It weighs abot 10 lbs now,I'm sure there is only a little in there,but I only need 1-2 lbs ,maybe or even less?
Old 06-03-2013, 11:58 PM   #12
HVAC1000's Avatar
i weighed one of my empty ones. it was just under 8 pounds 9 oz
Old 06-04-2013, 12:01 AM   #13
So I probably have very little,thanks.
Old 06-05-2013, 05:55 AM   #14
An old Tradesmen
Rewards Points: 6,464
R410A cylinders average 9 pounds. They have no tare weight stamp on them.
Using Weight Scale as a switch blackbrawler Electrical 24 03-27-2013 12:50 PM
Disposable Glove Recs? Fed Up w/Home Depot Cheap Shredders! Lovegasoline Painting 8 07-15-2012 08:04 PM
Chainsaw repair - cylinder damage? holmes55 Tools 3 01-01-2012 07:23 PM
R410a acessories JJboy HVAC 4 05-25-2011 09:10 PM
Cost of boiler & cylinder replacement abaminog Off Topic 9 03-31-2010 08:05 PM
