R410a Acessories - HVAC - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 11:59 PM   #1
JJboy's Avatar
R410a acessories
Summer is around the corner. I haven't work yet on R410a system. I have Testo 550. I want to buy set of hoses with a ball valve, Core removal access. What else do I need for R410a system?
-Does the service valves for R-410A systems have 5/16" access port?
-Does the R410a refrigerant cylinder have 5/16" access or 1/4" access?
Thanks yall
JJ
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 05-25-2011, 04:42 AM   #2
An old Tradesmen
Rewards Points: 8,174
Their 1/4 inch, unless your working on a mini split, then their 5/16". The R410A cylinders are all 1/4". Just remember, the cylinder is on a 25 pound cylinder, not 30 like R22.
Old 05-25-2011, 09:55 AM   #3
JJboy's Avatar
Thanks beenthere. I just need hoses with a ball valve instead low loss fittings.
This one here right?
http://www.yellowjacket.com/product/703
Old 05-25-2011, 06:04 PM   #4
JJ I'd recommend the regular ends and add on the ball valves. That way if you're like me and just plane hate the things then you can take them off and screw on the low loss.
Old 05-25-2011, 08:10 PM   #5
An old Tradesmen
Yep, those are the ones I use.
I cleaned them up for that pic.
First replacement unit R22 to R410A high efficiency JJboy HVAC 24 04-25-2011 08:07 PM
Charging R410A system best practice JJboy HVAC 11 04-25-2011 05:59 PM
Mini-split heat pump R410A norm01 HVAC 12 11-17-2010 04:11 PM
Which works better - R410a or R22 HP/AC kb3ca HVAC 7 08-17-2010 07:50 PM
is a charging R410a same as R22 LLB62777 HVAC 8 04-08-2010 05:40 AM
