-   -   R22 or R410 A (http://www.diychatroom.com/f17/r22-r410-2204/)
mdmjcc 04-06-2006 02:05 PM
R22 or R410 A
I need to replace my heatpump and I am trying to decide between R22 and R410.
I have the inside unit in a finished basement. The ceilings are finished. If I change to R410, do I need to change the piping? And if I don't what are the ramifications of keeping what is already there?
Will it last, what would I expect to see in wear?
If I keep R22, how long will it be available?
didn'tdoit 04-06-2006 10:45 PM
Simple answer...go with the R-22, by the time it is really phased out there will be another type other than R-410A. Also, the 410a is a smaller molecule and leaks easierand has to be used at higher pressure..
dogma 04-26-2006 01:35 AM
Sorry mate but I completely disagree. :(
R410a systems are much better, and for the environment as well. As long as your pipe work does not exceed 5/8 the old copper "SHOULD" be fine.
Just remember to have a pro do the job and make sure he fushes the old oil and crap out if the pipe. Don't get dodgy dave refrigeration serives to do the job.:)
R22 is a HCFC and is nasty to the environment. The next phase of refrigerants you'll see coming on the market will be CO2. In 6 yrs time cola-cola amital will only use merchandisers which run on CO2.
Cheers.
:eek: :eek:
ASHMAD2BLUE 05-21-2006 04:47 AM
I disagree about being able to use the same piping because the pressures run almost two times as high on the r-410a I install units & I always go with a thicker wall pipe when converting to 410. The low side pressures run approximately 119 psi. on 410 compared to 69 psi on the R-22 systems. Thats a big difference.
