R12 To 134a Retrofit ? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 07:50 AM   #1
jkv
r12 to 134a retrofit ?
I got a call on a small refrigeration cooler found that the condensate drain tube was caught up in the fan causing compressor to fail so I need to change out the compressor found that it is an old r12 the ? that I have since I have not had to change any of these does this have a orifice in them or do I just need to flush out the lines?
jkv is offline   Reply With Quote
Old 08-28-2012, 09:37 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
They say it's best to change out all o-rings and hoses and whatnot. Hope this article helps.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/6af508537ad744fb85256b2700537df1/$FILE/4322304.pdf
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
jkv (08-28-2012)
Old 08-28-2012, 12:19 PM   #3
Rewards Points: 1,216
Might be easier and reasonable to replace the condenser if it is a small fractional HP unit and have a factory warranty.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 08-28-2012, 12:49 PM   #4
jkv
This is a old unit and the compressor will come on and about 30 sec. shuts down on overload.
Old 08-28-2012, 02:10 PM   #5
Replacement sounds good the compressor is likely stuck.
Old 08-28-2012, 08:30 PM   #6
Rewards Points: 242
is this a commercial unit or a house refrigerator?
is it worth to change out the compressor. they quit putting in R12
about 1993. The commericial units i work on that were R12, we use
R409. R409 takes the place of R134a. If you use R134a, the capitacy is a little less.
hvac instructor is offline   Reply With Quote
Old 08-28-2012, 09:01 PM   #7
AKA HVACTECHFW
Rewards Points: 1,208
I would use hot shot (R414B) or hot shot 2 as a replacement.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
plummen (08-28-2012)
Old 08-28-2012, 09:09 PM   #8
Rewards Points: 616
me to ....414 b 134a is useless hate it
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
Old 08-29-2012, 08:31 AM   #9
jkv
This is a commercial and I have been thinking about using 414 hot shot I think that would be the best, the compressor is 134a that they bought so I an not even sure what I am in for when I get there.
Old 08-29-2012, 08:58 AM   #10
wrong info, and answer.
Old 08-29-2012, 09:16 AM   #11
jkv
Yea, I think the real problem is going to be when I get their because instead of letting me order what is needed they ordered the compressor bad deal but they went over the owners head and I got the call from him and was assured this will not happen again. So I am just trying to get every idea that I can not knowing what I am going to walk into. This is a small commercial box they use in the kitchen as a prep table on the restaurant side.
Old 08-29-2012, 09:37 PM   #12
Rewards Points: 616
use 414b....... it will be fine.... no 134a it is awefull....
Reinstalling a retrofit window quark Windows and Doors 3 11-06-2011 11:26 AM
Retrofit window flashing question dragondoom295 Building & Construction 1 09-06-2011 09:08 PM
Measuring for retrofit windows mday83 Windows and Doors 5 08-14-2011 08:49 PM
How to do retrofit installation for a casement window without z-bar? forkshen Windows and Doors 1 06-22-2011 11:02 PM
Installing retrofit windows inside raised facade Improvised Windows and Doors 6 06-11-2011 07:12 PM
