R-410a - HVAC - DIY Chatroom Home Improvement Forum
Old 08-31-2007, 06:26 AM   #1
Rewards Points: 528
R-410a
Are there pressure guages to measure high and low side pressures just for R410A refrigerant or can a serviceman use guages designed for R22 and automotive refrigerants?
What would the error be if he did?
rjordan392 is offline   Reply With Quote
Old 08-31-2007, 10:48 PM   #2
I have a set of uniweld gauges that work with r-22 and 410a.
Rookietinner is offline   Reply With Quote
Old 09-01-2007, 05:39 AM   #3
Rewards Points: 528
Thanks,
I had responces in another forum that the oil in R410A is differant then whats in R22 and that they should not be mixed. There seems to be a conflict there. Perhaps the way the gages are hook up and removed prevents any contamination from getting into the compressor; would that be a reasonable assumption?
Old 09-01-2007, 01:21 PM   #4
jordan yes , the issue of the oils not compatible is valid . The pressures are very different , very much higher , as are the operating head and suction pressures. the manifolds and hoses are of different construction . Please get certified in 410a uses b/4 trying to use it. high side guages go up to 800 psi. We automatically change linesets when using 410 to aviod any problems. Good luck Jack
rojacman is offline   Reply With Quote
Old 09-01-2007, 02:30 PM   #5
Rewards Points: 528
Thanks,
I will not be handling the refrigerant. I am just aquiring information to make sure that the people I hire are using correct procedures.
Old 09-01-2007, 06:07 PM   #6
The combination R-22 and 410A guages are convenient, but the accuracy may not be good.
Go Bucks
Buckeyetech is offline   Reply With Quote
Old 09-01-2007, 07:33 PM   #7
Rewards Points: 528
Thanks.
While I have your attention, whats your opinion on using a Mason's hygrometer as a calibrating tool to set correct humidity readings on a thermostat. It has a dry and wet bulb spirit thermometers and I usually direct a flow of air towards it to give somewhere near 500 feet a minute to promote evaporation. Thats part of the directions in its use.
Old 09-01-2007, 09:13 PM   #8
I've never used a Mason Hygrometer. I'm now using a Fluke #971 but I can't think of a stat that we have around here that needs the humidity set, but any good hygrometer should do the job.
Old 09-01-2007, 09:43 PM   #9
Rewards Points: 528
I am not even sure it makes a differance as it may just be a monitor on the stat. But on the other hand, I can program the desired humidity level and the stat may be influence by the monitor reading. This is why I calibrated it to cover myself.
